Cars & Trucks Logo
Posted on May 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need detailed diagram of 1998 latch mechanism to remove connections from it
The outside handle on my 1998 Econoline E150 Ford van rear door does not acctuate the latch, although the inside one works. I took the door apart & removed the screws to take the latch out, but too many connections to power lock/key lock/handles that I can't get the latch mechanism out of the door where I can work on it. Where can I get a diagram of the latch mechanism & its connections?
Jason Phillips
Level 3:
President:
  • Master 500 Answers
  • Posted on May 29, 2009
Jason Phillips
Master
Level 3:
President:
Answers
500
Questions
Helped
180258
Points
1298
There is no diagram... the latch is also a non-servicable latch, so if your problems in the latch- it needs a latch. i would look more closely at the outside door handle itself as i have seen a few of them break on the E series vans.you may be able to get detailed instructions thru autozone.com or @ autozone. hope this helps and good luck
Need schematic on replacing rear door cables on Ford econoline van
that usually goes onto the top latch.. be better to remove top latch an visibly see the eye where to hook ur cable for solid connection.. very visible eye..cant mistake it .then proceed with the rest of install to exterior handle
Wiring diagram for rear door lock/handle
with or without memory locks can email you a diagram ,e mail me @ [email protected] give me year and engine size and is it a e150,e250 ext.
8helpful
2answers
The rear latch/handle on our ford freestar 2005 came off in my hand. it looks fine. I can;.t open the rear latch now. I got inside the van and removed the little plastic cap/tab the sits directly behind...
Here's how I repaired mine. Go inside and remove the plastic 2" square plastic cover. By pushing on the lever inside this area, the latch will release. Push on the door at the same time, when the latch is pushed. With the door open, remove all four screws from the plastic panel. Now pry carefully the big plastic panel off the door. There are plastic snaps holding this on, all around the edges. Now there is another metal cover over the latch mechanism under this panel. Remove this. You now can see into the latch area and put the handle back into the slot where it came out of. You'll see that the ends of the handle can be put back on the round bar, but to hold them in place, I attached 2 nylon ties on one end. You can also purchase a metal push on retainer from the local hardware store. Mine has been repaired for 8 months and had no trouble. Ford used no retainer on these handles and after prolonged use, they bend and the handle can be pulled off. A twenty minute job. Your wife can even do it.
Fred C
4helpful
1998 Chevrolet Venture Liftgate
it isn't that the cable is off I believe it will be that the mechanism is siezed. you will need to gain entry from the inside through an access hole in rear hatch door. once you get the door open you will need to remove the latch and oil it with penetrating oil and work the latch until it works freely
3helpful
1999 Econoline E150 Van mirror replacement
Remove the door handle bezel.Remove the power window/door lock switch bezel.Remove the rearview mirror fastener trim cover.Remove the 4 door trim panel retaining screws.One that was behind the mirror trim cover,behind the switch panel,behind the door handle bezel,and one at the bottom corner.Lift the door trim panel up from the door to disengage the trim panel clips.Remove the front radio speaker. Disconnect the power mirror wiring connector.Remove the 3 bolts to the mirror.
2helpful
2answers
Loooking for diagram
There is no way to post/attach such info on this site, I would suggest you try to buy a factory manual on ebay, they are much cheaper there than at the dealer who would want the dead to your house.
Door lock
When the actuator moves the latch up, it connects the outside door handle to the opening mechanism. When the latch is down, the outside door handle is disconnected from the mechanism so that it cannot be opened. So in this case your latch needs to be replaced, the latch or one of its parts is malfunctioning. the outside handle is never beening disconnected from the latch. remove the door panel visually inspect for damage, and take the proper repair
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
