SOURCE: Bosch Washing machine WFP 3300 Fault
Hi F01 is a low water pressure error and is caused when the
washer won't fill water, check the water inlet valve if that is fine and there
is no clogs in the inlet hose then the water level switch/pressure switch
should be replaced. Hope this helps...please post back for further assistance. Daniel
SOURCE: bosch washing machine WVT 126S,
F01 means the machine thinks that you have pressed start and the door is still open, so, either the door is not completely shut or you will need a new door interlock (part number 182154) you can get the part by calling 0844 892 8979 (UK) or http://www.bosch-home.co.uk/customer-service/spare-parts-accessories.html. Or the connection to the door lock is not loose or detached.Hope this helps
