I want to clean the spout but I do not know how to remove the front so I will be able to clean it. I've searched the internet but could not fins a solution. I do hope someone here can help me. Thanks, John Netherlands
SOURCE: Jura Capressa E9 Leaking
Your spout is probly cracked (a common problem). It won't hurt the machine if you want to live with making one cup at a time to catch it all.
If you want to get it repaired go to www.hotncold.com Click on Jura Repair for shipping instructions. We can turn the job around in 24 hours. The repair will also include a free software update.
SOURCE: Jura Impresso E9 not dripping through spouts but into drip tray
This is most likely due to a bad o'ring. The bar you speak of...Does the unit have a small spout pointing upward from the area?...with a groove? Is the o'ring in that groove damaged or missing? When the grounds are compressed in the piston, the brew unit lowers down onto this spout and seals on it. The high pressure water then is injected upward inot the brew unit. When this seal fails the water simply leaks into the tray when there are grounds providing backpressure. When rinsing and no backpressure some of the water may be getting through. Make sure you lube up any seals with a food grade lube. Olive oil will work in a pinch.
Mike
SOURCE: jura capresso z5 not working
Call Nick or Anthony at Style Cafe on 0844 2279229 they have a wealth of knowledge on these machines and can Service them if required
SOURCE: Espresso doesn't come out of the front spouts.
I'm having the same problem, did you solve it?
SOURCE: My Jura S9's grinding unit clogged (due to Peete's beans)
Use the TABLET CLEANING. please refer to this manual here on page 24 if you don't have one.
Regards
