SOURCE: I lost water pressure in my swimming pool line and
If your pump is blocked in any way (usually a closed valve), then the pump cannot keep water flowing. It could be starved of water if blocked on the suction side, or an air leak. On the return side, it's usually a ``dead head`` pipe, or a closed outlet valve. In either case, the pump can overheat and actually boil the water within it. In that case, the fittings attached to it can deform and cause bigger air leaks, which compounds the problem. If you replace the fittings, reconnect the pipe and remove any blockages, you should be fine.
SOURCE: hayward power flo lx swimming pool pump is making a grinding noise
THAT IS A ABOVE GROUND PUMP AND THE BEARING ARE GOING BAD, ITS HARD TO FIND A SHOP THAT WILL WORK ON ONE OF THOSE PUMP-MOTOR SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING AND HAVE HIM LOOK AT IT TO SEE IF IT'S A FIXER OR NOT ? .JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXYA GUY
SOURCE: HOW TO WINTERIZE AQUAMATE ABOVE GROUND SWIMMING
for winterize aquamate above ground swimming pool pump see here for information:
http://www.aurorapoolsandspas.com/products/1/1/Above_Ground_Pools.html
