SOURCE: mp3 player
Get firmware upgrade - it will reinstall the correct format
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
SOURCE: delete photos on V-Touch 8GB Video MP3
Deleting Files,Pictures,Videos,etc from MP3 Player
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Good Luck,
I hope this helps
Please rate me,
Thank You
SOURCE: hi there my daugters ipod touch 8gb screen gone
You may need to reset. Important: Only reset your iPhone or iPod touch if it is no longer responding. To reset, press and hold the Sleep/Wake button and the Home button together for at least ten seconds, until the Apple logo appears.
