Sharp AR-275 Copier Logo
A
Anonymous Posted on Jan 13, 2014
Clean drum corona wire - Sharp AR-275 Copier
1 Related Answer
Anonymous
  • 175 Answers
  • Posted on Jun 29, 2009
SOURCE: ar-m237 copier, getting black line thru all
A line could be anything from charge unit dirty, a rotational line on drum or possibly a fuser roller that has a line worn into it. Question? Are we talking a straight uniform black line or is it irregular fuzzy line that changes some? If it's fuzzy, probably charge corona wire or grid dirty or needs to be replaced.
Change drum kit
Remove the old drum unit,remove the drum and the drum cleaning blade,clean the charge corona wire and grid,install the new drum and drum cleaning blade,clean the image transfer /separator corona wire,clean the optical parts(mirrors ,lens,glass)clean the AIDC sensoe located under OPC drum,reinstall the drum unit in the copier,enter in the technical Rep mode,place 5 sheets A3 paper on the original glass and perform F5 AIDC sensor(Auto image density control).
Says drum error, see troubleshooting maitainance chapter in user guide. Don't have a users guide. Printer is brother mfc-7340
I have this manual for you. I can be reached at [email protected]
http://welcome.solutions.brother.com/bsc/public/as/as_ot/en/doc/manual_index.html?reg=as&type2=-1&prod=mfc7340_us_as&c=as_ot&lang=en&flang=all
Drum Error - The corona wire on the drum unit needs to be cleaned.
Clean the corona wire on the drum unit. (See Cleaning the corona wire on page 122.)
Cleaning the corona wire: If you have print quality problems, clean the
corona wire as follows:
a. Turn off the machine's power switch.
Unplug the telephone line cord first, disconnect all cables, and then unplug
the power cord from the AC power outlet.
b. Open the front cover.
c. Slowly take out the drum unit and toner cartridge assembly.
CAUTION: We recommend that you place the drum unit and toner cartridge assembly on a clean, flat surface with a sheet of disposable paper or cloth underneath it in case you accidentally spill or scatter toner.
Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
To prevent damage to the machine caused by static electricity, DO NOT touch the electrodes shown in the illustration.
d. Clean the corona wire inside the drum unit by gently sliding the green tab from right to left and left to right several times.
CAUTION: Be sure to return the green tab to the home position (a) (1). If you do not, printed pages may have a vertical stripe.
e. Put the drum unit and toner cartridge assembly back in the machine.
f. Close the front cover.
g. Plug the machine's power cord back into the AC power outlet first, and then reconnect all cables and telephone line cord. Turn on the machine's power switch.
1helpful
2answers
Printer says drum error see trouble shooting and maintenence care in manual. I have replace toner and drum
Drum Error:
or
The drum unit has reached the
end of its life.
Replace the drum unit.
(See Replacing the drum unit on page 130.)
and/or
press Clear/Back
Press Start, then 00
after the screen show "accepted"
close the front cover and you are good to go.
1helpful
The fax machine is saying remove the drum there is dust on the corona wire.
Use the corona cleaning wire to clean the dust off. Open the front cover. Remove the drum/toner unit. look on the right side of the drum portion above the toner unit for a plastic tab with a triangle arrow that points to the left. Slide this tab back and forth several times. Move the tab back to the right. Reinstall the drum/toner unit. Close the front cover.
Clean the corona wire in this manner every time you change the toner/drum.
12helpful
Drum Error on Brother MFC 7840W
Has two situations:
  1. The corona wire on the drum unit needs to be cleaned.Clean the corona wire on the drum unit.
  2. The drum unit has reached the end of its life. Replace the drum unit.
4helpful
2answers
Copies are black and where is this corona wire? I
Your cartridge has two sections, the drum and the toner section. The corona wire is on the drum section. There should be a blue tab on the top left hand side of your drum unit. Slide this tab across the cartridge one or two times, returning the tab to its original position. There should be an arrow on the blue tab that will match up with an arrow on the drum unit when the tab is in its resting position. Performing this action cleans the corona wire inside the cartridge. If this doesn't fix it you may need to purchase a new drum unit.
2answers
Same problem even with new Brother drum
Did you replace the drum or the toner cart? The drum has a blue lever that you slide back and forth around 20 times to clean the corona wire. I sometimes use a cotton swab with alcohol to gently clean this wire as well.
Cleaning the drum unit corona
Message is telling me that the drum is dusty. It says to clean the corona with the wire. I don't know what the corona is and I cannot find a wire that might help me know how to clean the corona
14helpful
8answers
Corona wire AND MORE SPAM 1-800-975-0148
I was getting the clean the corona wire problem message even after repeated cleanings.  Before this problem occured the toner light was flashing warning of low toner. When I got the clean the wire pop up the toner light was on all the time indicating the toner was depleated.  So, I thought I would try replacing the toner cartridge and see what happened. I opened the new toner box and noticed on the foil packege specific instructions to clean the corona wire when installing the new toner.  I installed the new toner and cleaned the wire one more time. I then reinstalled the drum and toner assembly into the printer and the clean the corona wire message did not come up again.  The printer now works fine.
4helpful
Pls Clean Drum
The drum is the larger plastic unit that slides out an the toner cartridge fits into it. The corona wire is the very fine wire at the front top of the drum. Just slide the little cleaning tab back and forth.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
