1991 Lexus LS 400 Logo
Posted on May 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No electric's, main fuse has blown, need to know location of same to replace. If possible, can diagram be sent?
Main fuse has blown, need to know location of same to replace. If possible, can diagram be sent?
Mike Vincent
Level 3:
Sergeant:
  • Lexus Master 358 Answers
  • Posted on May 28, 2009
Mike Vincent
Lexus Master
Level 3:
Sergeant:
Answers
358
Questions
Helped
188657
Points
1003
Under hood. you have to raise up the box and flip open side covers to unbolt 120 aNo electric's, main fuse has blown, need to know l - 41948728mp fuse.
I need to replace the main power fuse on my 1985 buick electra. I can't find it. Can you help me
The main power fuse on a 1985 Buick Electra is likely located in the engine compartment fuse box. The fuse box is typically located near the battery and can be found by following the positive battery cable.
If you are having trouble locating the fuse box, consult your vehicle's owner manual for specific location and a diagram of the fuse box layout.
The main power fuse, also known as the "battery fuse" or "fusible link," is responsible for protecting the electrical system from damage caused by a power surge or short circuit. The fuse is usually a large, cylindrical fuse that is located in the main power distribution circuit. It will be the largest fuse in the box
Once you've located the main power fuse, you will need to remove it to check its condition. If the fuse is blown, you will need to replace it with a new one of the same amperage rating. It is recommended that you use only fuses that are specifically designed for your vehicle, and that you consult your owner's manual or a professional mechanic for the correct amperage rating.
It's important to note that working on electrical systems can be dangerous if you don't have the proper knowledge, so if you're unsure about how to proceed, it's best to consult a professional mechanic.
JCB 8014 mini digger - Where is main fuse?
The main fuse on the JCB 8014 mini digger is typically located near the battery or the starter motor. Here are some steps you can take to locate the main fuse:
  1. Locate the battery: The main fuse is usually located near the battery or the starter motor. Locate the battery and follow the cables that are connected to it.
  2. Follow the cables: Trace the cables that are connected to the battery and look for a fuse holder along the way. The fuse holder should be a small plastic box with a lid that can be opened.
  3. Check the manual: If you have the owner's manual for the JCB 8014 mini digger, check the fuse diagrams to see where the main fuse is located.
  4. Check the fuse box: The main fuse may be located in the fuse box under the hood or in the cab. Check the fuse box for a large fuse that is rated at 60 amps.
  5. Consult a technician: If you are unable to locate the main fuse, it is best to consult a qualified technician who can help you locate and replace the fuse.
Once you have located the main fuse, check it for signs of damage or burn marks. If the fuse is blown, replace it with a new one of the same amperage rating. If the fuse is not the issue, there may be a problem with the wiring or the electrical components of the mini digger, which may require further diagnosis and repair by a qualified technician.
2001 cherokee laredo cigar lighter and power outlet not working. blown fuses replaced, still not working. power outlet fuse i pdc checked and good. could cigar lighter relay be bad?
No , can't be the relay , by looking at a wiring diagram the power outlet has different supply voltage . Fuse 1 25 amp is for power outlet an cigar lighter use's fuse # 2 25 amp. Free wiring diagrams here http://www.bbbind.com/free-tsb/ Enter vehicle info. year , make , model an engine size. Under system click on interior & driver amenity, then under subsystem click on cigar lighter . Click the search button , then the blue link. Looking at the diagram you will see they have different fuse's. Something up stream from there is blown . Need to look at electrical distribution diagrams. Go back to system an click on electrical distribution then under subsystem click on power distribution . Click the search button then the blue link. Scroll down to the # 6 diagram . You will see fuse # 4 50 amp location is under hood fuse box . Check that fuse .
2answers
1996 f150 no electric power
Blown main fuse or fusible link . Finding a electrical distribution diagram an using a volt meter to test to see where B+ voltage is missing is the way to find the problem . Do you know how to trouble shoot automotive electrical circuits ?
2answers
Brake lights on my 01 gmc sierra truck dont work but the tail lights, blinkers and emergency lights all work.
Could be the brake lamp switch is bad , stop lamp fuse 20 amp in under hood fuse box could be blown .Check the fuse ,if not blown check for B+ voltage at the brake switch , location - top of brake pedal under the dash . Do you know how to test automotive electrical circuit's using a DVOM - digital volt ohm meter ? Looking at a wiring diagram so you know which wires to test would be good too . Do you know what a wiring diagram is ? Free ones here http://www.bbbind.com/free-tsb Enter vehicle info. Year , make , model an engine size . Under system click on lighting ,then under subsystem click exterior lighting . Click the search button then the blue link. first diagram top left you will see the stop lamp switch . orange wire in is B+ voltage . Press the brake pedal while checking for B+ coming out on the white wire . No B+ coming out ,replace the switch . Will be other wires as well , other switch etc... check the right one .
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
1helpful
2answers
Show how to replace power outlet fuse for 2006 Toyota Camry
Interior Fuse Box Location 2002 2006 Toyota Camry 2006 Toyota Camry LE 2...
The video above shows how to replace blown fuses in the interior fuse box of your 2006 Toyota Camry in addition to the fuse panel diagram location. Electrical components such as your map light, radio, heated seats, high beams, power windows all have fuses and if they suddenly stop working, chances are you have a fuse that has blown out. If your Camry is experiencing electrical problems, you should always check the fuses first, because they are relatively easy to check and cheap to change. Some Toyotas have multiple interior fuse boxes including in the trunk - the video above will show you where the interior fuse box of your 2006 Camry is located. If your Camry has many options like a sunroof, navigation, heated seats, etc, the more fuses it has. Some components may have multiple fuses, so make sure you check all of the fuses that are linked to the component in question.
If you need to replace a blown fuse in your Camry, make sure you replace it with one that has the same amperage as the blown fuse. If checking and replacing the fuse for the component in question doesn't work, we recommend seeking assistance from a trusted professional mechanic. They should be able to figure out if the component needs to be replaced or if there is a short or some other problem with your Camry.
Good Luck
1helpful
1997 nissan maxima fuse box diagram
The fuses are color coded and will have the amperage rating printed on them. Unless all the fuses have been removed than there should be no need to replace the fuses unless they are blown. Which will be obvious if they are blown. If all the fuses have been removed let me know and I'll see if I can find some diagrams of you.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
I need to find out wher and how to fix the fuse on the front dash light
If you do not know where the fuse is, how do you know it needs "fixing"?
If your dash lights are not working, there is a possibility that there is a blown fuse. However, you need to realize that blown fuses do not cause electrical problems. Electrical problems cause blown fuses. So if you replace the fuse, it will likely just blow again if you do not fix the problem that caused it to blow.
On the other hand, there are several other things that could be keeping your dash lights from working that has absolutely nothing to do with the fuse.
With all that said, the fuse that protects your dash light circuits is a 7.5 Amp fuse that is located in the Instrument Panel Junction Block at the left side of the dash. It is marked "PANEL"
1helpful
Lighter socket doesnt work
It could possibly be a blown fuse, just find the fuse access panel under the dash,on the inside of panel should be a diagram that will help you locate the cigar lighter.If blown replace. If it is not blown, you may need to replace cigar lighter.
Need to replace a 20 amp fuse, for the auxiliary cigarette lighter, located on the right side of the console. Do not know how that is labelled, on the fuse box diagram.
Just take out your fuse box and see the fuse diagram there. If it was removed, just check one by one your fuses by visual check. You should found the blown fuse is disconnected ( melting) inside the body. None of instrument you need to use but visual check only. Then replace the blown one.
Regards, Jay
Top Lexus Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
Are you a Lexus Expert? Answer questions, earn points and help others
