HP Compaq Presario SR1230NX (PJ518AA) PC Desktop Logo
Posted on May 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power light flashing HP Compaq Presario SR1230NX PC Desktop I powered the unit down; when I tried to powered it up the only reaction is a green led flashing. The led is located in the back close to the receptacle where the 120 VAC are connected. The led is part of the power supply box. The led may be something like a power or function check. The led is flasing color green. No fan goes on or any other sign of life. I disconnected all borads attached t0o the mother board as well as each fun and every load from the power cables. Need a solution...
Ben Wabnick
Level 3:
  • HP Master 2,404 Answers
  • Posted on May 28, 2009
Ben Wabnick
HP Master
Level 3:
Answers
2404
Questions
Helped
883874
Points
7655
Sounds like the Power Supply is bad likes its not able to power on itself. Best thing to do, try a different known good power supply and attach it to the motherboard, if you get the same symptom with the machine not powering on then its a bad motherboard. If the machine does power on then you know your original power supply is bad.
  • Anonymous Feb 20, 2011
    if u disconnect the power cords from Motherboard and light on back is solid green wait til it goes out then plug them back in this is usually caused by a power surge so buy a surge protector
No power - LED light blinks.
hi
thank you for using Fixya
u have isuue with LED cables which you have conact on mother board you have to find that from the Internet or contact me
1helpful
2answers
Compaq Presario SR2150NX doesn't turn on. Front panel green light turns on but nothing else happens (no fans, no boot, no noise, nothing) Please advice
On the back of the Power Supply there should be a Green LED, When you power it on if it is flashing, this means that the Power Supply is dead and you need to replace it.
1helpful
Have a compaq pc tower and when i put the power cord in the back all i see is green amber light in the back flashing and no sound or any type of power on the pc.
Just because the light is on doesnt mean it has engough power to start all the components... Try opening the computer and unpluging the things you dont need to start the pc. ie cd rom drives, pci cards floppy drives, ect. If it boots than it is deff the power supply if not it may be either the power supply or motherborad or cpu!
2helpful
2answers
Hi have sr1200nx blinking green light no power took side off checked connections still not working any advice thks
Usually led flashes are a code that gives the problem.
Two sites that may help are;
http://www.user-guides.co.uk/download/compaq/compaqpresario/compaq-presario-sr1230nx-disk-download.html
Go to the end of this page to see code definitions.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bph07107
for more generic data
2answers
2helpful
Desktop with not turn on, green blinking light on back
Could have blown out your Power Supply to your PC. But I would at least try to unplug your PC and hit the power button to drain of any standing power, and then plug it back in and see if it will turn on. If not you probably at the very least blew out your power supply.
Wont start power supply binks
What do u mean u unplug the motherboard...?
Green light flashing after shutting down computer to relocate office.
if its by the power button the led just indicates power after u have removed its source and reconnected it........this is normal nothing to worry about.
Presario 6350CA won't boot
I don't know that I'm going to be a great deal of help, but here is the link to the support site for you Presario:
http://h10025.www1.hp.com/ewfrf/wc/product?product=390426&lc=en&cc=us&dlc=en&lang=en&cc=us
Here's a link to another page on the Compaq site that specifically talks about power supply problems:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=390426&lang=en#N514
They discuss a flashing power led on this site, but I believe they are referring to an led on the power supply itself. Perhaps the led on the keyboard and the led on the power supply are both flashing...
Good luck. I hope this helps.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
