Question about Kenmore 64802 Top Freezer Refrigerator
Whirlpool freezer defrosting and refr not cold
We have a Admiral Top Freezer Refrigerator Model#
sounds like a defrost problem. if the freezer section gets too much frost build up then it wont be able to move air into the refr section. check to see if you have "heavy" frost in the freezer and if so then a defrost thermostat or a defrost control board may be you problem.
Nov 02, 2013 | Admiral Refrigerators
We have a whirlpool et1rhmxkq03. I have replaced defrost timer and thermostat. Defrost timer seems to stall and freezer thaws and the compressor stops running. I tap the control housing in the refr
The problem is with the "thermostat" right next to the defrost timer. When you tap on the control, you are actually tweaking the thermostat and not the defrost timer. Here is the thermostat to order.
Here is a diagram of the control box. The thermostat is number 13 and the defrost time is number 4.
Nov 11, 2012 | Refrigerators
Whirlpool Refr. GB22DK lower freezer- not defrosting/Minin glacier developing under sliding basket. Has been leaking water onto floor. .
Water forming is due to a defrost condensate drain being blocked by ice or gunk. Click Here=> Leaking Refrigerators Just What may Be Happening
To see a larger image click Here=> Defrost Condensate Drain Blockage Read more on how to fix and repair this problem here=> Leaking Refrigerators! I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Refrigerators
Water leaking into bottom of refr
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 03, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
FAN IS RUNNING BUT FREEZER AND FRIG NOT COOLING whirlpool ED22TQXFW00
2 possible issues... 1 are you sure the freezer is not working, if the food is basically frozen, but no cool in the refr. then you may have a defrost problem, if no cool at all in both then a relay on the compressor has shorted out. relay is very common!
Dec 31, 2009 | Refrigerators
Whirlpool Model # GB2SHTXTS00 refrigerator not cooling. it has bottom freezer...coils in the freezer are icing up... I checked the heater, and stat ohmed ok.i ran the service test everything appeared...
Sounds like the defrost timer is not tracking the time properly. The unit needs to defrost once every 6-8 hrs. in order to work. Make sure the inside (evaporator) fan is running ok. If it rund for a few days and then warms up in the refrigerator section (coil iced), then the defrost timer is the culprit.
May 28, 2009 | Whirlpool GB2SHKXL Bottom Freezer...
Refr/freezer alternately gets too cold and thaws
My first thought: defrost timer which shuts off the compressor and turns on a heater in the freezer is sluggish.  I'd change it out.
Nov 15, 2008 | Amana Refrigerators
Kenmore 64802 Top Freezer Refrigerator Logo
19 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
