My screen is not broken so I know it isn't that-the camera is sound-solid
SOURCE: download pictures from finepix s2000 hd
If you are not able to find your connecting cable. and i am assuming your need is to transfer the data to comp. Well what you can do is you can take out the memory card and fix it into the card reader (you will get a card reader vey cheap anywhere.). and connect it to your comp. Now your card will work as a flash drive and you can transfer data easily then... Hope this helps you out.. :)
SOURCE: camera will not connect with PC to download pictures
Hi I am vortash .. check for damage on your download lead and around the camera plug interface .. check that the drivers are still installed and reinstall them to make sure ... if you have a sd card installed remove it as it may be lose in the socket and the camera is trying to read it and can't .. check your batteries are ok .. try it on another computer .. if all this fails sounds like the camera interface has broken constant plugging in and out can sometimes cause problems with a loose plug .. hope tthis helps Regards Vortash
SOURCE: Trouble uploading photos from my camera.
you need the driver for your camera so that the computer can read
SOURCE: Downloading pictures to computer
Did you disable the autorun on your computer? Is operating system detecting the cam/card as removable disk? Which program is downloading the pictures? (Check the program options)
