It sounds like the locking switch on the side of the SD card is in the "locked" position. Remove the card from the camera and slide the tiny switch on the card to the unlocked position. That should do it.
Use the menu to unprotect the image then you can delete. Also you can format the card but that will remove all the images on the card so make sure you've saved it elsewhere.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
you need a class 4 sd card. i had a class 6 8gb card with this problem. took 200 pics on holiday, only the first 10 worked, the rest say cannot play image.. look at www.kingston.com to find compatible card.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't do it, try a different card and see what happens.
If the image has a small icon of a skeleton key along the bottom when viewing it, it means the image has been protected. You have to un-protect the image to erase it. This is done from the Playback Menu (the one with the arrow on the tab). Specific instructions are on page 115 in the manual. (Manual is available here if you don't have it.)
