Canon PowerShot A75 Digital Camera Logo
Posted on May 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blue lines on my screen when I take a picture and on picture when it prints.
When I take a picture, there are blue lines that appear on the screen and these then transfer to the picture when I print it. You can still see the item you shot, but the screen is blue and so is the picture. What is causing this? Is it something that can be fixed?
CameraR
Level 3:
  • Canon Master 4,738 Answers
  • Posted on May 28, 2009
CameraR
Canon Master
Level 3:
Answers
4738
Questions
Helped
1195993
Points
12483
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Bizhub c200 printing with streaks of red and blue lines what to do
If that lines are consistent with the red and blue and it does not appear during black and white print that means the cleaning blade in the affected color units need to be replaced
A thick blue horizontal line appeared in my LCD screen and won't go away. I can still take pictures and they print out fine, but how can I get rid of the blue line?
This is probably a problem with your LCD monitor or the connections to it. Does the blue line show in all situations such as record, playback, and menu mode?
Test your monitor by plugging into your camera the TV cord that came with your camera. Connect to a TV and use it as a monitor when your camera is on. be sure to switch to the TV to channel three or video to get a picture. Check the different screen modes: record, play, and menu. If the blue line does not appear on the TV then there is damage to your monitor or its connections. My guess is you won't see the blue line on your TV since you get good prints. If you are on warranty, get it fixed. Otherwise, you have a choice between paying for a repair or living with it. Good luck.
1helpful
Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Weird blue flash when tv turns on or off
TV will need service soon, blue CRT is on its way out, will need replacing
Blue line problem with Sony Grand WEGA KDF-55WF655 Rear Projection TV.
We had the free repair from SONY for the blue dots and splotches. It works great now but you need to hurry and contact them as the offer expires I believe in December.
Blue haze on screen
blue haze on both sides of samsung plasma screen when goes dark or bright pictures. white lines on football ground appear blue???
Akai PT4298hd
You may need the change the coolant in the blue tube. Convergence is when the picture will look 3D Let me know if you need more information.
5helpful
2answers
Curved blue lines on screen.
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
43H70 Blue Convergence out of line and will not line back up
If the blue colors will not line up, and the blue appears to sag inward from one or more sides, then you can bet that one of your convergence IC's has either cracked loose or burned out. The IC should be resoldered or replaced and the convergence realigned by someone experienced with projection TV convergence circuits.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
