SOURCE: My cordless Black & Decker
Most likely it is the switch has gone bad or just a loose connection on the switch . you can take it apart and check the switch connections and make sure they all have a good connection.If they do then you should take a volt meter and make sure that when you puch the button they get proper voltage if not then order a switch and replace it .
SOURCE: Black & Decker Pivot Plus Cordless Drill/Screwdriver AC Adaptor
extend the handle straight and all will be reavealed! Just in front of the triger inside the piviot point.
Mike
SOURCE: Circuit diagram for charger for Black & Decker
You can contact a Dewalt Service Center to see if they have the diagram. Black and Decker is Dewalts lower priced line. A quick search on their website did not reveal anything. They may not have the diagram. As far as I know there are no parts available for the chargers so you may have a hard time locating the diagram. Try giving Dewalt a call.
SOURCE: charger not charging have 2 new chargers neither 1
You should probably contact Customer Service regarding this. I'd say it's a problem with the batteries rather than the chargers considering this looks like a recent EPC model - 1800 444 224
3.6v - 4.5v
