SOURCE: Slave jumper settings for a 2.5 Hitachi DK23DA-20F hard drive
Hello.
For most IDE drives, if you REMOVE the jumper, the drive becomes a slave. But, you'll also need to change "drive 1" in your BIOS to recognize the second drive.
If you look on the drive, there should be a scheme as to the mode (Master, Slave,etc.).
Hope this helps.
SOURCE: My Hitachi HDD HDS728080PLAT20 7200rpm gives a clankity-clank
Sounds as if your hard disc is failing
SOURCE: I connect my new 320GB hitachi internal hard drive
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to ......,press escape then press f10 to save to cmos to restart The BIOS is AMI. Under ADVANCED SETUP: ? ? single or master ::::: master with slave ::':: ???????????????? slave? :::': note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s ?????? ??????????????????????????????????????????? hope this helps ? ? ? ?
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
SOURCE: is there a jumper setting
There should be, look on the rear of the drive, close to the SATA and power connectors, you should see the jumper connections as well.
It varies from drive to drive, but the jumper setting could be engraved near the connector, look of SL for a slave setting.
If no, look on the label on the top of the drive, there should be the jumper settings listed there.
Some may be ambiguous, my last one offered the option of Master on / off. (Jumper in position 1 for on, no jumper for off) The off in this case was of course slave.
The result being, no jumpers - Slave.
