Question about Price Pfister 532-7PCC Marielle Pull-Out Kitchen Faucet with Matching Soap...
My price pfister kitchen faucet is unable to twist on the counter top after it is tighten down and it should , is there a part missing . F5385LCS
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
Problem solved.
Posted on Dec 05, 2008
SOURCE: handle on faucet shuts off on its own
I had the same problem. The Price Pfister web site recommends removing the handle (unscrew the dome cap, then remove the phillips screw to get the handle off) then tightening the retaining ring (I used channel lock pliers on largest setting. It worked. However the retaining ring is plastic on some models, and they recommend replacing it with a brass one. I haven't taken that step yet, we'll see how it goes (mine is plastic).
Posted on Feb 20, 2009
SOURCE: price pfister faucet handle drops and turns off.
Re the 'falling handle' issue, I think you misunderstood the problem, jgwhomeequip. Unfortunately for me I bought *two* similar Price Pfister faucets and both had the same problem - the water wouldn't stay on and the handle just wouldn't stay up.
I took mine apart looking for something to adjust, fruitlessly. Put it back together and have lived with it like that for ~2 years.
Finally I decided to not be a knucklehead any longer and call the manufacturer. Once I got through to their rep (on a Saturday no less!) she helped me identify the model I had (a 533-50SS, just FYI), and asked me 'what finish'? I replied 'stainless steel' and she promptly replied, 'I'm going to mail you out new lighter handles to replace the ones you have'.
Brilliant! Gold star for PP for standing behind their product well past the warranty for what was apparently a common problem. Replacing the handle will take about 10 seconds per faucet.
I only wish I had got of my a$$ and called them 2 years ago.
1-800-PFAUCET (1-800-732-8238)
Consumer Service Department:
7:30am to 4:00pm PST, Mon-Sat
Fax: 1-800-713-7080
Hope that's helpful to somebody.
Posted on Apr 04, 2009
SOURCE: 533-50 kitchen faucet leaks above base mount at
There are O rings that seal the various body parts of this faucet. I would try turning off the supply lines, removing the handle, and unscrewing the faucet and the housings. Look for O rings that seal each part. Could be a broken, or maybe some foreign material has gotten in the O ring grooves. Best bet would be to replace any O rings and tighten it all back securely. It should not have any Up and Down play, should only swivel side to side. I'm thinking O rings. While there, you can replace the seat seals and springs, so that you preclude any leaks from the faucet itself. Lowes, Home Depot, carry the repair kits for these faucets at a reasonable price. And they usually include the allen wrench and wrench to remove the handle and the body parts. And they are relatively inexpensive. Around 4 to 6 dollars. Its an easy fix.
Posted on Sep 27, 2009
SOURCE: I can't disconnect the quick connect sprayer hose Price Pfister
Squeeze the bottom half of the 2-piece black plastic cylinder that connects the sprayer to the faucet. Gently pull down on the hose. If the connector is not a 2-piece cylinder, you need to push the connector up, as if you were connecting it, and while it is pushed up tight, pry up on the small ring on the top and gently pull down on the hose. I know it sounds like you need 3 hands, but it works (even though it is a pain).
Posted on Apr 22, 2010
Aug 03, 2013 | Price Pfister Marielle Kitchen Faucet with...
Feb 19, 2013 | Price Pfister Plumbing
Sep 28, 2010 | Price Pfister Marielle Kitchen Faucet with...
Apr 10, 2010 | Price Pfister Marielle Kitchen Faucet with...
Nov 22, 2009 | Price Pfister 532-7PCC Marielle Pull-Out...
Sep 27, 2009 | Price Pfister 532-7PCC Marielle Pull-Out...
Jun 11, 2009 | Price Pfister 34-3LC Genesis Kitchen...
May 04, 2009 | Price Pfister J103-BC 100 Series Kitchen...
Apr 13, 2009 | Price Pfister 34-3LC Genesis Kitchen...
Dec 01, 2008 | Price Pfister Marielle Kitchen Faucet with...
Dec 26, 2012 | Price Pfister 532-7PCC Marielle Pull-Out...
35 people viewed this question
