Wont stop filling with water
You need to replace the fill switch its not sensing or stopping the w ater. It is fairly simple. Remove the plastic molding on the ends. Remove two screws holding down the control panel. The fill switch is over to the left, and has a clear tube attached to it. Remove tube and wires, lift tab keeping it from turning, turn 45 degrees and remove switch. Replace and test in all positions. Good luck whirlpool is a good brand.
