Mitsubishi WD-65C9 65" DLP HDTV Logo
A
Anonymous Posted on Aug 16, 2017
Background Frozen. HELLO, WHEN I TURN ON THE TV ONLY SHOW ME THE BLUE BACKGROUND SCREEN MITSUBISHI WELCOME. I TRY SELECT INPUT DEVICE, OPEN MENU, OR CHANGE VOLUME BUT I CANT. THE STATUS LED IS GREEN AND FAST BLINKING. WHEN I PRESS ACTIVITY AND CH DOWN, STATUS LED CHANGE TO CODE 12. NO ERROR. I TRY DOWNLOAD THE UPDATE, RESET TV, BUT DONT HAPPEN NOTHING, ALL IS FROZEN. SOMEBODY CAN HELP ME. THANKS.
5 Related Answers
Anonymous
  • Posted on Dec 28, 2006
SOURCE: Mitsubishi WD 52525 & PS 3
First make sure your hdmi cable is connected from the PS3 to the TV. Then go to netcommand, review, and make sure "monlink" is checked, click next, and finish. Select "monlink" from your device manager and turn on your PS3. If the screen is blue, go to the next step. Connect the PS3 via regular a/v cables to the front panel "input-3". Create a net-command device for input-3 as well. Switch to the input-3 device you created and turn on your PS3. Choose display settings, and change the settings to HDMI. Then click change. You'll have 30 seconds to hit device manager, change the device to "monlink", and let the PS3 unit know the setting has worked. From there you can configure. Good luck!
Anonymous
  • 39 Answers
  • Posted on Nov 12, 2007
SOURCE: Mitsubishi 56231 Turns on but no picture or sound
HEY DJ SOUNDS FAMILIAR TO ME AS THESE SETS SEEM TO FAIL IN THAT WAY WHEN THE CAPACITORS IN THE POWER BD. AGE/WEAKEN.I PROPOSE A CALL TO A MISTUBUSHI EXPERIENCED TECH THAT CAN REPLACE THE 6 CAPACITORS AND YOU/LL BE WATCHIN' HD AGAIN. JOE TV
Anonymous
  • 145 Answers
  • Posted on Feb 12, 2008
SOURCE: Error code 1 2
I found this list of codes
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Anonymous
  • 179 Answers
  • Posted on Nov 17, 2008
SOURCE: Mitsubishi wd52525 shows error code 37
error code 37 is either the dmd fan or the lamp fan. you can see the dmd fan with the cover off. you cannot set the lamp fan as it is under the light engine. I guess the easiest thing to do is get a lamp fan 299P282010 and a dmd fan 299P283010 and change them both.
Anonymous
  • 201 Answers
  • Posted on Apr 30, 2009
SOURCE: My Mitsubishi 65 inch DLP will not turn on.
looked up owners manual that was a waste of time, hmm the number one issue on this type of set is issues with the lamp. How old is it? Has it ever been replaced? Sometimes a visual inspection of lamp can fool you, but typically as they age a milky haze develops on the lamps glass or if it popped the lamp will be shatttered inside. Can't hurt to check it. make sure set is unplugged first just to be safe.
How do i erase a frozen web site off the front of screen
Change your desktop by going to display properties. Right mouse button click on the screen in any blank area, select personalize from the bottom of the menu, select desktop background from the lower left of the screen, change to a different background, save and exit.
tip
How can I get a background on my iPod Touch 4.0
<p>IPod Touch 4 uses a touch-screen interface. A feature of the iPod Touch 4, its ability to set the background image displayed on the home screen of the device to change. You can use this background image at any time if the device is "Settings" menu. The device allows you to select pre-loaded images of the background or use a custom background image of a camera device to create roll. <br /> <p><br /> <p>1. Touch the "Settings". <br /> <p><br /> <p>2. Select the "background" option. <br /> <p><br /> <p>3. Select the icon of the background image. This is the only photo available after selecting the wallpaper. <br /> <p><br /> <p>4. Select the "background" to select from pre-installed wallpaper. Touch the "Camera Roll" button to a custom photo image stored on your iPod Touch to select. Select the photo or your own photos to use as wallpaper on the device. <br /> <p><br /> <p>5. Tap the "Set" button to install the new wallpaper on your iPod Touch. <br />
on Aug 05, 2011 • Apple Ipod Touch 4
Desktop background doesn't show
I get this too. (Love using the solid blue background)
1. Check if there are any other users logged in on the Mac.
2. Log off all the users including yourself
3. Log in only on your user account and change the background
If that doesn't work, restart first and repeat.
If even that doesn't work, change to another solid background first and then change it back to the picture.
Logon Change
Enable Log-On Screen
Windows, by default, is set to show the Welcome screen during startup.
To enable the log-on screen to show, go to "Start" menu and select "Control Panel".
In the control panel, click on "User Accounts".
In the "User Accounts" dialog-box, click "Change the way users log on or off" and uncheck the "Welcome Screen" option.
Click "Apply Options" to save the changes.
Change Log-On Screen Background Color
To change the log-on screen background color, go to the "Start" menu and click on "Run".
In the run dialog-box, type "mspaint" as the name of the program to "Open".
Click on "OK". In the "Paint" window that opens, select "Colors" from the main menu and click on "Edit Colors". In the "Edit Colors" dialog-box, select "Define custom colors".
Here pick the color of your choice and note down the "Red", "Green" and "Blue" values.
Write down these values somewhere.
Click "Cancel" and close the paint window without saving. Now, go to the "Start" menu, click "Run" and enter "regedit" as the name of the program to "Open".
In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\COLORS and double-click the "Background" string.
In the "Edit String" dialog-box that opens up, change the values in the "Value data" field to the red, green and blue color values that you wrote down (e.g. 75 78 173).
The default value will be 0 78 152. Enter the values in the correct red-green-blue order, separated by a space. Close the registry editor and log off to see the changes.
Put Image in Log-On Screen Background
To put your favorite picture in the background of the log-on screen, click "Start", then "Run", and type in "regedit". In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\DESKTOP and double-click the string "Wallpaper". In the "Edit String" dialog-box that opens up, enter the full path and filename of the image that you want to use as the background. The image must be in .bmp format. Click "OK" and close the registry editor. Log off to see the changes. hope this helps
I need help changing my background on my Gateway LT20 Series
Hi there and welcome to Fixya!
I'm guessing you're referring to the Windows desktop background. But if not, please provide additional information.
The Windows desktop background is the image on the desktop that appears behind the shortcuts. To change the background, please follow the steps below:
1. Open the "Display Properties" screen by placing the mouse cursor over a blank area of the desktop. Click the right mouse button to access the context menu and choose "Properties". You can also access the "Display Properties" screen by clicking on Start, select Control Panel, and then Appearances and Themes. Open the "Display" shortcut.
2. Select the "Desktop" tab from the "Display Properties" screen.
3. Pick a picture from the Background list by clicking on it and click on "Center, Tile or Stretch" to select the position. Personal pictures in the "My Pictures" folder are listed by name in the Background list.
4. Choose a background picture in another location by clicking on the "Browse" button. You can use any files with the following extensions: .bmp, .dib, .gif, .htm or .jpg. Click on "Center, Tile or Stretch" to select the position.
Audio is okay-blue screen will show on no input-audio can be heard but dark screen when any input has a signal. It is detected as 480 but no video,,,no raster on rf inputs Have electronics background can...
the problem is solved by expert electronic, because your tv have cpu program and need reconfiguration this program,
And other question is you check cable conexion
you check conexion
you check format/image programing (NTSC/PAL) if in the setup or menu have the best configuration, no all problem is the component electronic...
oh, you read manual step by step...
bye
1helpful
Mitsubishi WS-55857 with a flickering blue edge.
The vertical IC needs to be replaced. You can get new Vertical output ICs at www.tvrepairworld.com and they will also help explain where its located.
1helpful
Image not seen on screen...only a blue background
go into the settings menu and select the computer input.
1helpful
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
