Black & Decker AV1200 DustBuster Handheld Vacuum Logo
A
Anonymous Posted on Jan 12, 2014
DustBuster blows out air from motor - Black & Decker AV1200 DustBuster Handheld Vacuum
2answers
Repair extreme loud motor noise on B & D DustBuster HHVK515.1, after wife ran it without any filters for one vacuuming job.
The only thing to do is to replace the damaged motor.
Probably more cost efficient to replace the complete machine.
Jan 19, 2024 • Vacuums
6helpful
How do I clean filter on black&decker DustBuster pivot 18v
(The below worked with my 9.6v version - I assume the others in the pivot range will be similar).
If you open the lid (where the dust collects) you can twist the inner plastic filter about 30 degrees to unlock it. Then, with a bit of "fiddling" with the fold out part (press the unlock button and rotate the suction part as if you were going to use the unit) then, the plastic internal part and the whole suction bit will come off the motor part. Do this slowly as the inner filter will be full of dust and muck. You can then take the filter out, tap it clean in the bin and then wash and dry it with washing up liquid (gently) and allow to fully dry before putting it all back together again.
Power is very weak
1) Test the power cord
2) Test the belt is worn and replace it
3) Test the motor need lube, and repair.
God bless you
I need a black and decker dustbuster manual to know what kind of batteries to buy. I recently got this dustbuster at a garage sale. The charge/wall mount says it is a 9.6volt FVE9610 Type 1. Help? Joan...
I have bad news. That part is no longer available; check out the info here:
http://www.ereplacementparts.com/black-and-decker-fve9610-dustbuster-parts-c-4167_8887_8911.html
I actually have exactly this kind of dustbuster, and I was able to renew the battery pack, but I had to do it by using eight individual cells and soldering them together. The size of cell (I think it's called a sub-c) is not common to consumers, but is fairly common to battery pack manufacturers. Quite honestly, your dustbuster with no battery is worthless, even when it was available, the pack was $46.46 as a spare - probably more than the thing is worth. Buy a new one from wal mart! If you really, really want to look at getting a new pack for this one, then your only option is to find a specialist battery store (I know there's one in my city) that can 'remanufacture' them. Basically, they take the old pack, and rip out the old cells, and put in new ones. They have the special equipment to weld the connections without frying the cells too, and they have access to Sub-C cells, of course. It'll be expensive. Good luck, you're gonna need it. Sell it at a garage sale; it looks nice.
Feb 05, 2011 • Vacuums
How do I clean the filter? can it or any part of
The fliter can be tapped aginst a garbage can to release soil. Using compressed air outside to blow off remaining soil and dust. The manufacturer will have replacement filters available.
User manual needed.
Black and Decker website offers product manuals. Also, various online vendors provided information I needed about DustBuster in product description, making it unecessary to purchase manual.
Charging Black & Decker Dustbuster
Leave it in the charger for at least 7 hours and then try and see if it works on a full performance time of roughly 3 minutes.
3helpful
How do I open the dustbuster to clean out the end
There should be an area to press at the joint between the front section, and the motor section. The whole front cone comes off to empty the contents, and there is a filter - but no bag with these.
Hope this helps you.
Thanks for using Fixya
The dustbuster part of my electrolux pronto 2 in 1 keeps getting stuck. I cannot eject it out of the main piece in order to use it on its own.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=543675
Generic problem for all Vacuums
Posted by nrosener on Apr 25, 2008
The dustbuster part of my Electrolux pronto 2 in 1 keeps getting stuck. I cannot eject it out of the main piece in order to use it on its own.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Sorry you are having a problem, I would suggest that you take it to an Electrolux dealer or try you local vacuum cleaner dealer in your area, all it may need is a slight adjustment to the back of the dustbuster or the part that releases the Electrolux dustbuster, it may be to tight and would need and adjustment or replacement in order for the item to release properly. So If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 25, 2008 • Vacuums
4answers
REPLACEMENT FILTERS
I suggest calling customer service.
http://www.blackanddecker.com/CustomerCenter/
Incidentally, the model number you gave is a 3.6 volt vacuum.
Top Black & Decker Vacuums Experts
Ngoro
john h
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
