SOURCE: How to replace the door?
You can usually find helpful exploded view diagrams and order any needed parts by entering your full model number here.
If the door won't lift off when you open it all the way, then you'll have to pull the oven from the wall to take off the cover and get to the hinges.
Kitchenaid / Whirlpool customer installation manuals and owner's manuals can be downloaded here
Hopefully you can do it without having to actually remove the hinges, since that would require adjustments and leakage tests.
SOURCE: Handle Replacement on a HKMS155L Microwave
I think you have solved your problem already.
I have seen your requesty only now and I am sending the diagram to replace handle.
You remove door latch (nr 3 on diagram) first, then you unscrew the screw nr .8 and remove handle (nr.7).
Below the diagram:
You can find all parts and diagram for your appliance here.
SOURCE: How do i replace the door handle
with most microwave ovens, for safety reasons... they are permanently sealed to prevent microwave leakage burns... i hope this helped you out..
SOURCE: kitchen aid khms147hss0 microwave - handle broke
Door parts are available separately on this model.
The parts manual is here. And you can order parts here.
You have to separate the door panels (as shown in the attached photo)
and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
SOURCE: Inneed to replace the door handle. I have the
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and/or replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. However, price and configuration of your oven also depends upon the MODEL NUMBER.
If you have any questions, please post back and let me know. If the model number you listed this quesiton under is correct, you can refer to pcappliancerepair.com for some excellent exploded view diagrams of your microwave that confirms how the door is assembled. The part numbers for a new handle (if you haven't purchased one yet) are:
8169737 - (White)
8169738 - (Black)
8169739 - (Biscuit)
8184264 - (Stainless)
Make sure you use the correct part number when ordering to ensure you get the correct color to match your appliance.
I hope this helps you.
