I need vacuum bags c151c and I can't find them any where. Can I use other style numbers, instead of the ones they specify.
SOURCE: how do i open a electrolux ultralux 2000
Before removing the rubber bumpers and plastic side strips, pry the rear section from the canister by pressing in the hidden tabs. The end section should pop off, revealing the side strips.
Be sure to diagram the wiring connections by color code before disconnecting anything inside.
SOURCE: electrolux 2000 Mod# c151c
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
http://evacuumstore.com/
SOURCE: What size vacuum bags does
It takes the "C" (canister) bags made by Home Solutions for Aerus Electrolux vacuum cleaners.
Testimonial: "Thank you very much."
