Dell 3100cn Laser Printer Logo
Posted on Dec 09, 2017
Load Tray 1 024-965
My Dell 3100cn is giving me isssue loading paper from Tray one how can I get it to use the mvp tray instead Ihave called Dell and they mentioned I should buy a new tray 1 however is there an immediate correction by using the other tray Thanks I have a Load Tray 1 024-965 error. There isplenty of paper in the printer.
Wisest 1
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Aug 25, 2018
Wisest 1
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
11668
Points
11
Dell 3100cn Color Laser Printer Error 024-965 - Load Tray 1
Cause:
The "Paper Tray Inserted" sensor buttons are not being depressed by the Paper Tray so the Printer thinks no Tray is inserted even if the Tray is properly inserted.
If you pull out the paper tray and look at the Paper Tray opening, you will see three white vertical sensor buttons along the left-hand side at the mouth of the aperture where the paper tray slides in. These three white vertically aligned push button sensors tell the printer that the Paper Tray is inserted when the paper Tray is
properly pushed all the way in and aligned. It also signals to the printer by noting which button is depressed whether the tray is a Letter Size or Legal Size tray that has been inserted. These buttons which are fully visible as soon as the tray is slid out can move out of place and even fall into the wall of the Tray slot preventing the buttons from sensing the tray.
Solution:
Click it back into place. There should be no play and the buttons themselves should be the only thing that move and then only in an in and out manner. They should move out toward you when the Tray is removed and be pushed in when the tray in slid into the paper tray feedering slot. A pair of needle-nose pliers may be necessary to draw the button module out of the tray slot wall if it has fallen in. Once it is STIFFLY repositioned and the Paper Tray reinserted, reset the printer by opening and quickly reshutting the printer cartridge compartment. This action will recalibrate the printer, shut off the amber error light and resume the current printing job if one was in progress.
5 Related Answers
Anonymous
  • Posted on Jun 02, 2007
SOURCE: Envelope printing
Got a 3100CN and had the same problem but found that a) Changing paper size from the web doesn't work but b) Go to the printer control panel on the printer and use the menu to set the paper size for the MPF tray for FREE. Now your application under windows will overide the whatever the printer thinks and will print. Envelope via Word all work without problem. Suggestion . Configure two printers one B&W using tray one and one colour using MPF and you can now quickly select whether to use colour or b&w. Regards John N - N2UYI/G7LTQ
Anonymous
  • Posted on Jul 11, 2008
SOURCE: Dell 3100cn Printer will not print
I had to actually change the settings in Microsoft Word to resolve this problem.
If you go to page setup > paper source > there should be lists for "first page" and "other pages".
You can set this to "as per printer settings" and hopefully it should work.
childofsai
Anonymous
  • Posted on Jul 28, 2008
SOURCE: ERROR 024 -965
I could be wrong but have you checked the paper type and size is the same on both the computer properties and on the printer. If in computer properties you have covers 2 selected then the printer will continue to ask you to load media until you have selected covers 2 on the printer menu.
Anonymous
  • Posted on Sep 29, 2008
SOURCE: load tray message
I remedied this a few times for a client...
If someone queues a print job in another size, let's say legal, instead of letter, the printer will cache that job as 1st in line until it is loaded with legal paper. I initialized the NVRAM of the printer and that took care of it every time.
Anonymous
  • 69 Answers
  • Posted on Nov 12, 2008
Please follow these steps:
Cycle Power on the Printer
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3100cn-series specifications.
Multipurpose feeder
Standard 250-sheet tray
Optional 250-sheet tray
Optional 500-sheet tray
Optional duplex
unit
S
L
S
L
A4
Y
Y
Y
Y
Y
Y
Y
A5
Y
Y
Y
Y
Y
N
N
B5
Y
Y
Y
Y
Y
N
Y
Letter
Y
Y
Y
Y
Y
Y
Y
Legal
(8.5 x 13 in.)
Y
N
Y
N
Y
N
Y
Legal
(8.5 x 14 in.)
Y
N
Y
N
Y
N
Y
Executive
Y
Y
Y
Y
Y
N
Y
COM-10 envelope
Y
N
N
N
N
N
N
Monarch
Y
N
N
N
N
N
N
C5
Y
N
N
N
N
N
N
DL
Y
N
N
N
N
N
N
User-specified print media
Y
N
N
N
N
N
N
Dell 3115 manual feed doesn't work
If this printer is a few years old on the load paper tray there is 2 grey rubber rings they get a flat spot on them. replace and no paper problem till the next time they wear out
Problems getting printer to respond after clearing paper jam
hi try this http://support.dell.com/support/edocs/systems/3100cn/en/UG/section19.html your printer error is mentioned and a solution offered good luck
2answers
Whenever a print job is sent to my dell 3100cn laser printer, ?Load tray 1? appears in the small window of the printer. I loaded the tray several times but it doesn?t work. Please guide me through the...
You sent a paper size different of the requested by the printer. Just load the requested size or delete the spool.
Some PDF downloaded from internet has A4 or 8,5x11", maybe is requesting one of this sizes.
If you can not delete this message, delete the spool using the printer manual in the control panel of the printer.
I have a dell 926 series printer lost the booklet how do i load the paper
You posting shows a Dell 3100cn printer (laser), but you say it's a 926 (inkjet). If a 3100, pull the bottom paper cassette tray out and load the paper. Make sure the sttigs for the paper are correct, e.g. "Letter". If it's a 926, the paper goes in vertically at the top rear of the printer.
1helpful
I have a Dell 3100cn that will not print as it continually states Load Tray Letter. The tray is loaded, I have rebooted multiple times any other thoughts?
The paper sensor is likely malfunctioning or there is a paper jam causing the printer to "think" that there is no paper in it.
1helpful
The printer message says: load paper tray and it is already load
Something to try, The paper (roller) may be slipping on the paper giving false reading of Load paper tray. UNPLUG THE PRINTER FROM MAINS and CLEAN the (roller) as best you can with quick drying solution, Tape cleaner or Similar. Good luck Bob.
Can't print envelopes
you need to select tray #1, manual feed.
tray #2 is auto feed- 8x11 sheet paper.
Printer won't print says Load Tray 024-964
Make sure that the paper is the same size as requested by the print job.
Ours is setup with A4 paper and if someone tries to print something setup for Letter paper it just flashes
Load Tray
Letter
2answers
Dell 3100cn gives message load front tray even though paper tray is full
if this unit is a bit older, than it's possible that the sensor switch is stuck
http://tinyurl.com/6qcpgy
3helpful
5answers
Envelope printing
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
