Question about Audiovox Sps Cdc-t04 Cd Changer Interface For Toyota
I have a cdc 800 changer. my on and off switch will not turn off. it displays e1 after the dealer installed a trailer wiring harness with the electrical break. it was working great before. the dealer said no wiring to the changer was touched. also, the changer runs constantly. we cannot remove pack. please help.
How do I install a wiring harness on a 1996 Chrysler Concorde to pull a trailer hook up the light harness
Lots of late model cars are fitted with a plug designed to make fitting a towing harness easy. Yours might have one of these, the dealer or the handbook should be able to tell you this.
Again lots of late model cars have a CAN-BUS system and in the absence of an integrated wiring socket a five-way relay and an independent supply should be used to power the trailer. This is a good idea for every car that must be wired the old-fashioned way even though it takes longer and costs a little more because the vehicle switches do not have to cope with the additional current load of the trailer lights.
Wiring the old-fashioned way can be made easier using Scotchloks but stripping the wire leading to each light and soldering the towing harness (or the relay harness) to it and re-insulating and finishing with a tiny cable tie is the best way for a reliable and long-lasting job. More detailed instructions are usually supplied with the towing harness.
Don't forget to also install a direction indicator (audio or visual) repeater alarm or tell-tale.
Mar 28, 2016 | Chrysler Cars & Trucks
How do i fix the brake lights
sounds like a wiring issue,, otherwise put your headlights on Auto and drive it as is.
Jun 25, 2014 | Jeep 2002 Grand Cherokee LAREDO
I need to know witch wires go into witch hole on a aiwa cdc-x927myuc head unit
on the wiring harness going into the back of the radio or the wiring harness going out to the car? ... if its the radio then you can buy one from on ebay for 6 bucks AIWA WIRE HARNESS CDC X407 CDC Z137 CDC X927M NEW AI 01
May 09, 2014 | Aiwa CDC-X207 CD Player
"CDC MECH ERROR" on 2009 Honda CR-V EX-L with Nav
Either the unit's motor is bad or the mechanical parts are dirty not allowing the unit to change CD's or load them.
Jan 23, 2014 | 2009 Honda CR-V
I turn the left signal light on and it works fine, I turn the right signal on and the vehicle right blicks, but the left trailer blinks. All brake lights work. What is wrong? Ground connects are good
Who installed the wiring on the vehicle ( dealer, self etc.)
Was trailer wiring pre installed or someone else did it
How old is the trailer?
it seems that there is a bad connection on the vehicles wiring. perhaps wrong part was used or connection from vehicle right turn- to wiring harness is not hooked on properly. Depending on how confortable you feel, test to see if there is proper electrical current flowing to the wiring harness ( right turn, left turn, brakes, headlights) you should be able to detect which area on the harness does not get power when the vehicles right blinker is on. It is not too complicated, just requires deductive reasoning and a tester ( about $5 at Kragens) No harm will come to your vehicle's electrical system by doing this; worst case scenario: you blow a fuse.
If vehicle is working properly, it will be a bad connection on trailer
Dec 21, 2010 | 2008 Ford Escape
The changer does not detect CDs in it. After
Optical pick up replacement required to rectify this problem
Nov 26, 2009 | Yamaha CDC-697 - CD changer 5-Disc CD...
Where is the wiring harness located on a 1997 Jeep Grand cherokee
On factory installed trailer package. The harness is located on right rear quarter panel back (inside) The trailer connection is just below the bumper. This harness can be purchased at your jeep dealer
May 14, 2009 | 1997 Jeep Grand Cherokee
I just installed the 7 pin factory trailer harness but i have no right turn or trailer markers . 2005 nissan frontier
In the passenger side behind the plastic kick panel there is a control module that works the trailer lights, if you got the towing package. My lights were malfunction and it turned out the unit in the kick panel was not wired up properly from the dealer. Have a dealer check it or get the installation diagrams from a nissan dealer or the web and investigate your module on your own. Best of luck.
Apr 09, 2009 | 2005 Nissan Frontier
Connecting lead for Blaupunkt CDC-A03 changer
If you can find the installation instructions, you may be able to use individual spade connectors either male or female and connect direct.
BLAUPUNKT CDC A03 Operating And Installation Manual Page 9
Or try somewhere like Crutchfield
Blaupunkt CDC A03
Mar 02, 2018 | Blaupunkt CDC-A03 10-Disc CD Changer
Audiovox Sps Cdc-t04 Cd Changer Interface For Toyota Logo
43 people viewed this question
Top Audiovox Car Audio & Video Experts
Marvin
Marvin
Ekse
Mark Skinner
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
