My Ac adopter is on but when plugin to laptop for charging it will not showing chaeger light and its not charging also.
Before looking for a replacement charger, try this:
1. Remove charger from power socket
2. Remove battery
3. Hold the Power On button on the laptop about 10 seconds (while the battery is removed), and release
4. Plug in the charger to the laptop and power socket (without battery)
5. Try to turn on the laptop
Check also that all the cables from the charger are connected firmly.
If this doesn't work, you will need to replace the charger. Take the laptop with you, so you can try the new charger on the spot to be sure.
SOURCE: Dell latitude D600 battery charge light flashing
You have a ground fault issue in the DC JACK.
There are escentially 4 circuits in the jack and one is not making contact.
1: Negative Charge circuit (outter ring)
2: Negative Run circuit (outter ring)
3 Positive (Inner Ring)
4: Signal (center pin)
I believe the negative charge circuit (outter ring) is not making contact internally. Typically what happens on that model DC Jack is the tension contact metal becomes fatigued, and does not touch the outter ring.
This could come from Heat causing early fatigue of the metal.
Or normal wear, the metal has simply worn out from regular insert/removal.
Don't forget to rate suggestions
SOURCE: dell inspiron 6000 not charging
I have a Dell Inspiron 6000, and so does my wife. One day coming back from the airport, the power adapter cord(the end that plugs into the laptop) was hanging out the door and was dragging on the ground. Well the end was unusable and I was out looking for another AC adapter. Dell wanted $80 for a new one, but I found one on ebay for $40. But once I got it, I found that it would power my laptop, but wouldn't charge my battery. I thought, I know the old one works, so I cut the end off the ebay one and wired it onto the original one but ended up with the same result. Called the ebay seller and turns out these AC adapters are dell seconds. They claimed to test them and offered to send me another one and did so. By that time the new one from dell dropped to about $40 so I just bought it too anyways. The new dell one worked and the second one from the ebay seller did the same as the first one he sent me. I found out that the dell laptop wont charge the battery if the supply goes below 19.5V. By me hacking the other end on the original AC adapter, didn't result in the best insulated connection from the other wires. Also, if anyone know anything about AC adapters, is that they have a "Step Down Transformer," and the company that makes them, low balls the windings so that if they are off on the voltage, they are under, and not over, thus not frying the more expensive laptop. My suggestion to you is to just pick up a new AC adapter from dell. Also, the rubber coating on the cord is pretty soft and splits easily.
SOURCE: My dell Inspiron 1318 laptop's battery is not charging.
check power supply see if its putting out voltage to laptop
SOURCE: Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
SOURCE: problem in charging of dell
If the charging LED is on but the battery is not charging then the battery may be worn out.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall.
ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time.
Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
