This seems like a lubricant issue. Most of these machine require some grease around the belts or arms. If this machine is still under warranty I would call up the company to grease it up for you. Same thing happened to me, but not this model.
Thanks
Bloomfield Computer Service
(BCS)
I’m happy to help further over the phone at https://www.6ya.com/expert/alex_8bda69cf9239121b
SOURCE: my Nordic Track E 4400 treadmill sqeaks loudly when in use
Hi again, OK thanks, The belt slides on a track and can get debris or other things that stick and is probably causing the squealing. There are belt cleaners and dressings and lubricants but the best place and the best product for your treadmill can be found at this site:
www.TreadmillDoctor.com They offer many bits of advice and how to on many different kinds of treadmills and can tell you how to clean and apply their product. Good Luck to you, this should Fixya!
SOURCE: Treadmill slows down and stops
hi..probably the reason to this problem may be due to
worn belt and deck or a belt that needs lube.
check it out..
thank u..
kindly rate my response..
SOURCE: Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Testimonial: "Although I haven't attempted this solution, but it makes perfect sense and will attempt it as soon as I get back to the treadmill - Thank you"
SOURCE: Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
SOURCE: need manual for nordic track walk fit 5000 1995
I can't help with the manual. But, if you reach under the area where the readout is, push up on the cord or any of the opening underneath the display will pop out. You should be able to find the battery compartment. The unit uses 2 AA batteries. If you find a manual, let me know.
Thanks.
