Question about Hobart Handler 140 Mig Welder
My motor on my hobart handler 135 is not working to make the wheels roll to feed wire. I disconnected it at the connectors and tested it and was not getting any readings on my meter as if it was not g
The numbers on the motor is S3009E/00504
  • Hobart Master
  • 10,543 Answers
Make sure the trigger switch is applying power to the motor. If there is no reading when you checked for OHMS then the motor is open. You'll have to get a new one.
Posted on Jan 16, 2014
3 Suggested Answers
6ya staff
SOURCE:
repairtech99
Rod Sims
  • 767 Answers
SOURCE: hobart handler 135 feed motor for wire doesn't
check the SCR ,looks like a big transistor mounted
to a heat sink or some of the older units had a relay
in-line with a fuse , I have a older Hobart and it is
a great little welder. If you snap a pic of the P.C.
board and email it ill rsheehan@northernsteeldesigns.com
point out what parts to check.and replace.
Rob
Posted on Dec 06, 2009
ewegotitfarm
  • 3 Answers
SOURCE: hobart handler 135 wire feeds for about a two feet
This happens to me all the time. Wear and tear has taken its toll and everything has to be maintained for it to work. Most likely the welding tip is worn and should be replaced. Lincoln electric tips work well and I will replace mine several times during the day. Also check your tension and make sure the wire will uncoil freely from the spool. You can remove the tip and make sure the wire will feed without it. If not, your liner may be worn out. Also a welding Jell will help keep the tip from cloging. It will still happen, but hopefully not on your first weld of the day.
Posted on Feb 04, 2011
Wire feed is not stable on Hobart handler 135
is this a lower end machine ? the cheaper machines take the power from the welding transformer to power the feed motor and as a result the feed isn't stable, also is the wire liner and tip in good condition if not replace them, try blowing through the liner with compressed air to clear any dust from the wire
Sep 17, 2013 | Hobart Welding Tools
Hobart handler 135 wire feeds for about a two feet then stops feed motor runs well under no load
Jan 15, 2011 | Hobart Handler 140 Mig Welder
Hi I have a Hobart 135 Handler the problem is the feed motor only works for a few minutes of welding and then slows down or stops the goes slow again.
First there is a overload for the drive motor incase the welding wire gets jammed. I've had one of these for a number of years and only recently understood the markings on the drive wheels. When the wheel is installed, the markings for the wire size is for the wire you're using. In other words, the marking is towards you but is indicating the size for the rear groove. For years, I looked at the numbers and assumed that they were for the groove closest to the numbers. I had no problem with solid wire, but with flux core all kinds of trouble. So, make sure you have the right groove for the wire size. Second make sure there are no kinks in your hose. Make sure your contact tips in the gun are the right size for your wire and in good condition A person has e a tendacy to make ther drive wheels tighter when the feed slips, this can cause problems for the flux core wire if the correct drive wheel is not selected.
Jun 21, 2010 | Hobart Handler 140 Mig Welder
I have a hobart handler 135 motor stops feeding
Take the drive motor off and blow out dust, chips, wire pieces, etc. and then rinse out with contact cleaner, blow dry, re-install. Had to do this every so often with mine. Hope that helps.
Jan 05, 2010 | Hobart Handler 140 Mig Welder
My Hobart Handler 120 needs a .045 wire drive wheel. Where can one be purchased?
Locate your locale Hobart welding distributer, or contact hobart, the are nice people and will give you all the avice you need.
Dec 26, 2009 | Hobart Handler 140 Mig Welder
Hobart handler 135 feed motor for wire doesn't feed wire. motor is ok I tested it with seperate power source. No power to motor from main board or ??????
Rob
Dec 06, 2009 | Hobart Handler 140 Mig Welder
You do not indicate if the wire is already out of the nozzle. If not, commonly the wire can jab the side of the tube it runs through and cannot advance.
IF the wire is already threaded, then there MAY be a fuse to protect the motor.
The click MAY be the gas valve, or the relay driving the motor and/or the main transformer for welding current. The circuitry for these is relatively simple and a voltmeter is your friend to troubleshoot this.
Oct 26, 2009 | Hobart Handler 140 Mig Welder
Hobart 135 wire feed sped control problem
you have a resistor down, first check the resistor on the centre pole then those going off to the two other pins
Oct 04, 2009 | Hobart Handler 140 Mig Welder
Hobart Handler 135 not feeding wire
try checking your heat selector switch. the pc board gets power from it. so the pc board relay may function (click) but have little or no power once the curcuit is made to the feed motor. it happened on my 135.
Jul 29, 2009 | Hobart Handler 140 Mig Welder
Seised wire inside feeding tube
You can replace the liner by removing the shroud tip, and pulling the spring (liner) from the machine end of the trifgger cable.
Liners are replaceable.
Dec 23, 2008 | Hobart Handler 140 Mig Welder
Hobart Handler 140 Mig Welder Logo
466 people viewed this question
Top Hobart Welding Tools Experts
David Soto
David Soto
rjivaro
Bryan Epland
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
