Kyocera Mita KM-2550 All-In-One Laser Printer Logo
u
unebe leunamme Posted on Jan 13, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kyocera KM2550 printer prints test page but cannot print word documents and pdfs
It was operating properly before this problem
Mike
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 167 Answers
  • Posted on Mar 09, 2014
Mike
Expert
Level 2:
Cheetah:
Answers
167
Questions
Helped
43843
Points
230
Try loading paper in the bypass on the left hand side of the machine.It may be that you are trying to print a document that is a different size to the paper that you have loaded in the copier.
3 Related Answers
Anonymous
  • 2120 Answers
  • Posted on Jan 15, 2009
SOURCE: Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Anonymous
  • Posted on May 16, 2010
SOURCE: Huge Margin with Kyocera FS 1000+
If the FS-1000 prints too far down the page or leave too much top margin or leaves a gap at the top of the page etc (<- for google searches). This is a problem with the felt pads on the three solenoids/clutch electro magnets that are under the right panel (2 under the engine/button board, 1 under the inner plastic cover, sometimes 4 in total on other kyocera printers). They get compressed over time meaning the metal leavers come into contact with the solenoid meaning they are released too slowly. Simply replace the felt pads with .5mm cardboard or another non-sticky non-metallic material. Too thick and it prints too far up the page.
Bevan Shaw
  • Posted on May 14, 2012
SOURCE: Kyocera FS1010 first page only half printed
I found this solution. Worked a treat. I took the printer apart and applied felts to the solenoids (the felt normally used for the bottom of cup coasters).
See the Success post in this thread...
http://www.copytechnet.com/forums/kyocera/15980-kyocera-fs1010-delayed-printing-1st-page-2.html#post55451
This manual helped too...
http://www.freeprintermanuals.com/PM/Kyocera%20FS-1010%20Parts%20Manual.pdf
This is the post...
Success
A solution has been found. Thank you to Steveauh (Townsville)
Kyocera in their wisdom have used a foam insulator on the 3 solenoids that disintegrates over time regardless of use.
  1. Open the right side of the printer
  2. Disconnect all connections to engine board
  3. Remove engine board
  4. Remove plastic guard (white)
  5. remove all 3 solenoids
  6. Replace all pads on the solenoids that come up against stops
    Registration Solenoid has 2 pads (1 against the solenoid frame and the other on a stop arm, the others just the frame pad)
  7. Keep thickness to around .4 - .5mm Too thick on register arm will cause early printing.
  8. Reassemble
And that is it. The arms were being magnetically delayed due the metallic contact. It seems to be a regular problem in this chassis FS1000 to FS1030.
Error code f245 in kyocera fs-2100dn printer
error printer if you print to internet corrupt document! shtdown printer disconnet cable cominication , to eliminate jot and retry print normal pdf or test page!
Printer prints test page but cannot print documents
install proper print drivers. Install the KX version 6 drivers
Kyocera 180 not printing documents
May need to look at manual. Make sure ink is good, paper in tray, drivers are installed on computers accessing it, connection is good. Perhaps try printing test page from printer to see if it functions at all
2answers
Black lines appear when printing on kyocera km2550
could be fuser tracking where the pawls ride on the heat roller, could be abrasions on drum, could be main charge corona, could be LSU glass. Can you provide a sample print?
HP Laserjet 1200 prints garbage when printing pdfs
it may be you have a virus in your computer
I AM USING KYOCERA 8030 IT NETWORK CONNECTED EVERY TIME I PRINT IT PRINTS TWO BLANK COPIES WHY?
are you facing same problem with other document like notepad ...... please check it please ..... open a notepad type some thing like test print and give print and check its comes blank pages or not .... if its not coming please check the document setting how many pages your document heaving you can give number pages you want to print ....... if you facing same problem with notepad please post you comment ........... and try to uninstall the printer driver and reinstall it ..............
1helpful
It keeps on printing test pages
Uninstall the PRINTER'S DRIVER SOFTWARE completely from your system, MAKE SURE YOU USE THE PRINTER'S DRIVER DISK FOR IT OR ANY UNINSTALLER SOFTWARE FOR IT DONT UNINSTALL IT FROM CONTROL PANEL.... DISCONNECT PRINTER, TURN IT OFF. Clear All Temp And Prefetch Files. Restart Your System, Turn On Printer, Hook It Up To Your System,,, Go To The Manufacturer's Website And Install The Latest Driver Software And Firmware If Available....
I bought two new cartridges for my printer but the printer prints funny. there is no color and the black appears faded. my printer is about 2 years old. have any ideals?
Sounds like the jets may be clogged. You may have to run multiple times till they are good. Print a test after each clean and see if that helps.  You can use the operator panel or the Lexmark X5100 Series Solution Center to clean the nozzles. Using the operator panel 1 Load paper in the All-In-One. For help, see page 16. 2 Press Options until Cartridges appears on the display. 3 Press the right arrow until Clean appears on the display. 4 Press Select. A nozzle page prints forcing ink through the nozzles to clean the clogged nozzles. 5 Print your document again to verify your print quality has improved. 6 To further improve print quality, try wiping the print cartridge nozzles and contacts (see page 44), and then print your document again. 7 If print quality has not improved, try cleaning the print cartridge nozzles up to two more times. you can get the owners manual on line at this address:  http://www.lexmark.com/publications/pdfs/x5150/eng/ug.pdf
please rate this and good luck.
1helpful
Printer will only print page 1 of multiple page documents
1. Check that you are using the latest print driver - from kyocera website.
2. If the issue is when you print pdf files then make sure you set the printer in KPDL Auto mode - check the print driver settings about this and the printer menu.
3.You may check if you have the latest firmware installed within the printer - print a service status page (Menu->Others->Service).
Top Kyocera Mita Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Bill Eager
Norman Weimar
Norman Weimar
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
