Konica Minolta magicolor  2490MF Laser Printer Logo
M
Mike Panfil Posted on Jan 13, 2014
Konica Minolta 2490MF will not print memory faxes
Device receives faxes, but will not print. Memory RX mode is set to "Off". RX Print is set to "Print RX". Device has been turned on and off several times.
PlatinumTechnologies
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Jan 16, 2014
Contributor
Level 1:
New Friend:
Answers
14
Questions
0
Helped
6217
Points
17
Firmware update required...
5 Related Answers
Anonymous
  • 214 Answers
  • Posted on Dec 31, 2007
SOURCE: Konica Minolta bizhub C250
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Anonymous
  • 167 Answers
  • Posted on Jan 09, 2008
SOURCE: Konica Minolta Bizhub 600 Malfunction Detected C-2807.
You need a service guy to stop by. Resetting the machine is a temporary solution only. Service will be able to print reports and see where the issue lies if it goes beyond just fixing a part.
Anonymous
  • 589 Answers
  • Posted on Feb 12, 2008
SOURCE: Call Customer Service 1-8O5-465-751O To Fix Issue Konica Minolta C250 Scanner problem
To print the transmission report:
1. Press the [Fax/Scan] key to display the Fax mode screen.
2. Touch [FAX Menu].
3. Touch [TX Report] on the Set 1 tab.
4. Select how to output the report, and then touch [Enter].
– Default: The transmission report is printed according to the previously specified method.
– ON: The transmission report is printed with each transmission.
– If TX Fails: The transmission report is printed only if the fax could not be sent.
– OFF: The transmission report is not printed, regardless of the transmission result.
Anonymous
  • 167 Answers
  • Posted on Feb 17, 2009
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Anonymous
  • Posted on Oct 15, 2009
SOURCE: Konica Minolta 2490MF - Paper size error
Need to set A4 size default on the printer driver itself.
Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences /
Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set.
Click apply.
should be o.k.
Our Konica Minolta BIZ HUB C10 message in window is MEM.RX. Can you explain what this means. Thanks
In the Fax/E-mail - Fax Configuration - Reception Operation page, set-
tings for receiving faxes can be specified.Memory RX Mode:
Select whether to allow ("On") memory reception or not
("Off"). In cases when confidential faxes are being
received, the received document can be stored in the
memory and printed at a specified time or when memory
reception is set to "Off". A password can be set to spec-
ify the starting time or ending time of memory reception,
or to cancel the function. The set starting time and end-
ing time are valid every day until memory reception is
turned off.
Choices: On, Off
Default: Off
Configuration Menu Equivalent:
RX SETTING - MEMORY RX MODE
How to print a fax confirmation?
USER MANUAL Page 3-34
Press STATUS key 3 times. Press YES. Press UP and DOWN keys to select the report you wish to print.
TX Result Report The document number, recipient name, date sent, starting time of transmission, number of document pages, time required, mode.
RX Result Report The document number, caller name, date received, starting time of reception, number of pages received, time required, mode, and reception result are printed.
The machine can also be set to print this report automatically after every 60 transmissions/receptions.
How to print from memory using a CANON MX 310. Also why fax es to memory instead of prining drectly?
  1. Issue: How do I print a document stored in memory?
    Solution: Print the received fax from memory - MX310
    Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press to clear the error then attempt to print the fax from memory.
    1. Press , then press . [FAX SETTINGS] will appear at the top row.
    2. Use leftright.gifto select [MEMORY REFERENCE].
    3. Press .
    4. Use leftright.gifto select [PRINT DOCUMENT] or [DELETE DOCUMENT].
      If you select [PRINT DOCUMENT]:
      1. Press .
      2. Use leftright.gifto select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the numeric buttons. If you are unsure of the transaction number, print the MEMORY LIST
        Press .
      3. Use[ left.gif] to select to print the first page only, or use [ right.gif] to select to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
      4. Press .
      5. To print another document, return to step 4b, or to finish printing, go to step 5.
        If you select [DELETE DOCUMENT]:
      6. Press .
      7. Use to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the numeric buttons.
      8. Press .
      9. Use [left.gif ] to select to delete document, or use [right.gif ] to select not to delete the document.
      10. Press . To delete another document, return to step 4g, or to finish deleting, go to step 5.
    1. Press .
24helpful
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Di152f-cannot receive faxes.
clear the memory then in service mode
METER COUNT
STOP00 STOP01
PRESS 11
PRESS THE START KEY UNTIL CLR appears
THE PRESS the START key to blank it out the in will reappear
POWER off the machine wait ten seconds and power on
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2answers
I have a konica bizhub 200. We can send faxes out
As a first thing to try, with most faxes that send but do not receive, it's usually down to a glitch.
Try shutting the bizhub down fully, then unplugging it physically from the power source for at least 30 seconds. Plug it back in and turn the unit back on, then have someone try and send you a fax.
If this does not remedy your problem, please indicate with a follow-up comment.
1helpful
5answers
I am still unable to receive faxes that are printed automatically when they arrive. they mst be going to memory and i cannot get them to print out of memory. can yo please help me. i paid for this service...
If you are getting a low ink message no you will not be able to fax until this is resolved. Once you replace the ink cart. then you can get to the steps where you can clear the fax memory until then the steps that we would give you will not work.
You can visit www.canon.com click on your printer model then on support and you can download the manual in this manual there will be step by step instructions on how to clear the memory on the fax. this can also be cleard once you print them keep that in mind. so first purchse ink then your going to print your faxes by hitting that button twice the reason why it will not work now is because your low on ink.
If you like this solution please hit accept.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
7helpful
2answers
Click apply.
should be o.k.
Memory RX, Recording Printing JAm
yes you can! if you really want it! you may enter the menu and in printing menu look for rx and press enter, or look for print from memory! it should work
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
