Maytag 24" Built-In Single Gas Wall Oven - Stainless-Steel Logo
A
Anonymous Posted on Jan 11, 2014
Maytag double oven and fsei error code
When I turn on the self cleaning part of the oven I get an FSEI error code
5 Related Answers
melissa40404
  • Posted on Jun 03, 2008
SOURCE: How to user self cleanning feature for oven
my oven is on f 9 cant turn off and get oven door to unlock
Anonymous
  • Posted on Nov 13, 2008
SOURCE: F1 error
I have had the same problem and the machine is 12 years old - serviceman who came told me the console can be replaced for $400 - I am opting to purchase a new oven
Cleverer2
  • 298 Answers
  • Posted on Apr 08, 2009
SOURCE: maytag double oven-top cleans itself-bottom reads unavaiable?
Either BOTH cannot clean at the same time b/c they heat to 700deg and use alot of power, OR the 'Door secure' signal from the bottom oven is not getting to the controller. I suspect if that is the case, the switch is on the inside of the door, activated by the LOCK lever moving into locked position. It may be a beny switchlever, mis-adjusted LOCK lever or solenoid or disconnected wire.
If you leave the TOP open and force a clean, does the bottom lock and do nothing? (My other theory)
Anonymous
  • 43501 Answers
  • Posted on Apr 26, 2010
SOURCE: Cleaned bottom oven. Top oven door won't open
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Anonymous
  • 1555 Answers
  • Posted on Oct 01, 2010
SOURCE: My wife tried to use
F4 fault code stands for Open or shorted oven temperature sensor. The remedy is to Replace oven temperature sensor. Click on the link provided below to see how the oven temperature sensor looks like.
http://www.applianceaid.com/pictools/Tempsensors.JPG
Replaced control panel and keypad 1 1/2 years ago seen the error codes now I was self cleaning oven everything went off no error codes or anything house breaker ok PLEASE help.
Self clean is hard on controls. I do not recommend self clean. Kills expensive parts. If the temp goes above 300 in the control panel, a control panel fuse will melt, killing the power to the control.
It looks like this:
Service manual for late model whirlpool double oven
and some more interesting oven stuff
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2helpful
When I set my oven to self clean it states FSEI. What does this mean?
Hi
F5E1 means the self clean latch will not lock.
Try pressing down any key for 1 minute, F2 may appear, then press CANCEL and see if that clears the fault, if not you may have a faulty door switch.
Dec 17, 2010 • Ovens
2answers
I have a whirlpool oven self-cleaning.. get code F5E1 or FSEI, when i set the self cleaning?
I live in apartment with a Whirlpool dishwasher and oven. Today was my first day to do automatic clean. After two minutes the "F5SEI" would pop up, then the door would unlock. I repeated this a couple of times. My mind wondered about a water source; perhaps the dishwater. Fortunately, I had a load of dishes ready to go. So I started the dishwasher, then the automatic clean on the oven. Behold! They work together like homies :)
I am trying to start my self clean and a minute after I hit start a beeping with this code appears: FSEI
Make sure that the door latch is completly locked and then try again. If it is locked and you are getting this code the door latch assembly is bad. The oven sensor would be fine since you get no codes during normal baking. Problem is in door lock system
I have a maytag gemini double oven and the bottom oven door will not open
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
1helpful
My whirlpool oven door is locked. After cleaning
HI. This will indicate that the door lock mechanism is damaged. follow the procedure below to address further.
If the door is latched:
A. Disconnect power from unit.
B. Check wires and connectors from control to door switch, then from door switch to control. If there is no damage to the wires and all connectors are okay, proceed to step C.
C. Replace door switch.
D. Re-apply power.
E. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
NOTE_ This will, normally, lead to the replacement of the door latch assembly.
1helpful
F10 Error code on double oven.
Sir,
Check out this link
suggest to reset it by shutting off both main breakers to the stove , wait for one minute and switch breakers on again.
Thanks Good Luck
Appreciate to rate as "Fixya"
Self-clean turns off after 5 minutes with F2 error message
Hi MaryB,
F2 error code means that the oven temperature is too hot. You will have to replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
F1 error
Top Maytag Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
