Buzzes when door is open, chirps when buttons are pressed, clock works, when I put a time in and start, it starts but immediately switches to "pause" and buzzes. The clock works and the nite light will work without buzzing, but just about everything else results in the loud buzzing noise,
SOURCE: 1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
SOURCE: Buzzing noise, wont work???
The magnatron is shorting, overloading the high voltage transformer. From the picture this looks like an older unit and is probably not worth a magnatron replacement.
SOURCE: G.E. Spacemaker XL1800- Loud constant buzzing noise. Help
My microwave was totally dead. Things I discovered: 1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this! 2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace. For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
SOURCE: Dacor DMT2420s when started makes a loud buzzing sound
The fan could have an obstuction. I have heard of tech sheets getting into the fan and causing a vibration and vibrating sound.
SOURCE: control panel not working properly
That's almost always a defective filter capacitor on the control circuit board.
We regularly repair such control units for
customers nationwide by mail for $39.95 postpaid in about a
week or so with a one-year guarantee.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more information & help.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
