Just bought a 2008 GMC Acadia. We just had a Kenwood 570 radio installed and the XM radio goes out randomly for long periods of time and also the radio will go out when making a hard right turn. I have taken it back to the car audio place 4-5 times and they are unable to fix the problems. The last time I took it in they connected a Maestro GM5 interface and harness and this did not help. If you have any suggestions or answers I'd greatly appreciate it! Thanks, Robin
SOURCE: 1996/volvo/4 dr/850/GLT
First, all these mechanics that you took your car to, did they have the full Volvo diagnostic software? In other words, were they able to access ALL computer systems that the lights were on for? If not, take your car to the Volvo dealer or a shop that has the proper software.
If the alternator does not charge or drops out while the engine is running, it will cause ALL the warning lights to come on.
Did you try adjusting the dash light dimmer control?
SOURCE: New Car Radio, New Harness but no power, Nissan P/U '95
here is the factory harness wires and what they do, recheck thayt it all matches up.
1995 Nissan Pickup Truck Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Gray
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
SOURCE: 2008 gmc acadia low beam light bulb changing
how do you change the low beam light bulb on the 2008 gmc acadia
SOURCE: 2003 Liberty Engine Swap Blown Motor How to fix timing.
Hey, did you ever figure this out? Ever consider swapping PCM's for a newer 04 PCM that would be tuned for this engine?
SOURCE: 2008 hyundai getz wont start
I just worked on a different model Hundai with the same sounding problem. I discovered that the starter was drawing to much voltage and starving the ignition system not allowing it to fire. I ran an amperage draw test and when it was discovered that it was the starter that was the culprit we replaced the starter with a rebuilt starter and it cured the intermitant starting problem. I hope this helps solve your problem.
bigc
