what is the memory error message? are you getting an error message that says memory is running low? if you got this message, do an upgrade with your memory. that will solve the problem.
Having a "System Error" message display on the camera's LCD display generally indicates a problem where the camera will need to come to Nikon for repair. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
Use the memory card that originally came with the camera (or a Nikon approved card) [/*]
Do these errors appear at system start up? Did you recently install any programs? If you did, uninstall the program, that should solve the problem. If you didn't install any program before the error messages, perform a system restore.
I think your windows media must have been impure. The best solution is format the c drive and reinstall the your operating system which op system you have been used so far. This will solved your problem.
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
