The washer is pumping some water into the tub during the spin cycle. This is causing the clothes to be wet after the spin cycle. When I manually shut off the valve for the cold water during the spin cycle, the clothes spun damp as they should.
U need a technician for that... there is a problem with the "flow valve" sorry can't help u out much with that... but maybe u can visit this site and hit the like button... www.facebook.com/muktidayasewa
SOURCE: washer continues to spin slow in the last spin cycle.
Red Ryder, the motor is 1 speed on this model. A couple of things to check; one would be the belt. Look for shavings, cracks or if it's shiney, could be worn. If your p number is p1118410ww, looks like you have 2 belts, agitate and spin and pump. Pump-R0606507, spin-R0606539. Check the pulley, make sure it is not binding, lube it up, and check the pump, something might be binding there. As long as you don't have a grinding, howling noise during spin the bearing should be good. Catriver..post back.
SOURCE: AMANA WASHER WILL LEAKS WATER IN TUB AFTER SPIN CYCLE.
Cylon, sounds like you need to replace the water inlet valve. It's not seating and weeping water. For series 10 the part number would be 40097701. Not that hard of a job. Catriver..post back.
SOURCE: Amana Washmachine (not all water removed during spin) ALW780QAW
you may have blockage in the drain pipe several feet from washer. if you can run spin cycle with hose in different location ex. tub,sink or outdoors. if this works run long snake down washer drain pipe to clean gypsum residual.
SOURCE: Can hear washer spinning but tub isn't spinning
Check the belt and replace it, Ithas either borken or has become loose. You can remove the back cover and get to the belt. Remove it or if it is broken just take it into a local hardware store and buy a new belt. Looking at about 10 dollars max to buy
SOURCE: spin cycle leaves clothes very wet
The clothes are wet after spinning
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
