Regardless of my settings or the current lighting, the flash bulb won't even pop up. It will use the focus light to focus when objects are dark, but when on auto flash or any other flash mode, it will not pop up or flash.
If you have set the main dial to the green camera logo, with automatic in bad light, and the flash still does not pop up, you could start worrying. The mail mode dial is very easy to turn, even without knowing. It happens to me more often than I would like. My next camera must have a special button to lock this dial.
When you chaco the manual, you will see there are settings the flash won't pop up and even when it is up it won't flash, because that menu excludes the flash.
SOURCE: Nikon CoolPix Flash Problem
This happened to me too!
Turn the dial to setup, push the menu button & select reset all. This will restore the defaults & let you use the flash again.
SOURCE: Nikon D40 will not flash
The lightning bolt icon in viewfinder blinks when flash is not ready, this can happen if flash doesnt pop up all the way, or if flash strobe tube is bad.
SOURCE: Nikon D60 - can not shoot pictures in low light
Quick solution: enable the "auto ISO" setting in the menus. This will automatically recognize low-light conditions, and adjust the ISO accordingly.
SOURCE: Why is there a delay?? Nikon D90
Sounds like you turned on Exposure delay mode (menu d10). This is similar to the "locking up the mirror" (or somethign) feature on canons.
YOu only need it when you doing a tripod shot with long exposure and you want to minimise absolutly all possibility of shake from the camera its self. Lifting the SLR mirror will cause small shake. Generally you can turn this off (i've felt it ona few times my accident and been confused for a second)
SOURCE: Nikon S210 flash not working
The flash has been working fine until last night when I tried to take a picture and the flash was set to auto. When I press the button the little red light beside the flash sign lights up, but the camera does not take the photo. When I set it to flash mode, it still won't take a photo. When I turn off the flash, then it does. What could be the problem? Is it in the settings?
