check whether your tablet has a hard reset available from any external buttons, ... a hard reset should set the machine to factory default and clear any passwords but you will almost certainly lose any data on the memory.
If you supply details of make and model and repost the query we might be able to track down a mothod of achieving access
Hello there,
From the Zeki website it says do this.
If you have set the screen lock to a password or pin code, and have forgotten the code; you will need to reset you tablet to factory default setting.
Make sure your tablet has a full charge
Press and hold the Volume - button and tap the Reset button
(The reset button is located between the HDMI and USB ports)
Continue holding the Volume - button until the boot screen appears
Release the Volume - button
Use the volume controls to navigate to "Wipe data/Factory reset"
Press the power button to select
Navigate to "Delete all user date"
Your table will take several minutes to reboot to a factory default setting.
Hi there, you can reset your wifi device by holding Down something on the litle whole on the site, and if you tell me wich model i can tell you more about resetting
I hope this will solve your problem. To reset your tablet go into the settings there should be a privacy section, tap that and then there are options of backup accounts if that is checked you should have no problem getting your password back. Also in that same section should be Factory Data Reset. Tap that and your device will automatically reset.
