GE JVM1650 1000 Watts Microwave Oven Logo
DEEPAK BIST Posted on Jan 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I HAVE A NATIONAL MICROWAVE WHICH STOPS AFTER TWO SECONDS
THE MICROWAVE STOPS AFTER TWO SECONDS./ HOWEVER, IN CONVECTION MODE IT WORKS PERFECT.
Devabhakthuni Venkateswara Rao
Level 2:
Champion:
  • Expert 225 Answers
  • Posted on Jan 13, 2014
Expert
Level 2:
Champion:
Answers
225
Questions
0
Helped
84953
Points
295
MAY BE DEFECT IN MAGNETRON SECTION MAY BE HIGH VOLTAGE NOT COMING FROM HIGH VOLTAGE UNIT OR MAGNETRON
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Aug 10, 2008
SOURCE: JVM convection microwave
I see. Okay, well then I would expect there's a problem with a high voltage part, such as the diode, magnetron or transformer.
Your model number should be entered as JVM192002 and you can find exploded views here.
You can usually find GE parts for much less here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Anonymous
  • 25 Answers
  • Posted on Jan 14, 2009
SOURCE: Daewoo WM1010CC convection/ microwave combo unit issues
Likely takes a torx wrench or some other special star tool to open it.
Could be a bad relay a bad mag tube or a bad timmer or a bad door switch. Needs to be trouble shooted. You have to get it open and check the fuses and test the voltage on the pri transformer first.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jan 19, 2009
SOURCE: GE #JE1590BC01 will convection & combination, but not microwave
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
(if it's not shorted or burned, it's probably okay)
Accessing some components for testing will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
The owner's manual will also tell you how long your magnetron warranty is - it's usually 5 to 9 years.
Anonymous
  • 180 Answers
  • Posted on May 29, 2009
SOURCE: Convection Oven has stopped working
magnetron may be defective . replace d magnetron
Anonymous
  • 72 Answers
  • Posted on Dec 30, 2009
SOURCE: My convection microwave will not heat up in
    usually if convection fails means there is problem in magnetron you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; contact a service technician.
please do rate me on the above said issue
Advantum GE 120 microwave/convection oven is smoking when I try to preheat the convection part. It's 2006 model w/the house we bought in 2 mos ago. Prior owner never used that part.
When convection mode is used heater inside gets heated and as you say that the previous owner never used this mode,when ever the heater used for the first time it may produce smoke as the coating over it heats up giving smoke,no need to worry use it regularly it will work perfectly
Microwave trips and switches off within 2 seconds
We regret reading about your microwave. At this time we recommend you have the unit evaluated by an authorized service center.
www.panasonic.com/repair
Need user manual for National model no: NN-8655 Microwave oven user manual...
I would suggest that contact the dealer from whom you purchased the oven or call any number listed on the model tag of the oven.
1helpful
Amana OTR Convection Microwave runs 59 seconds and shuts off
This sounds like either a thermistor or a damper switch/motor problem.
Amana's technical support line is 866-426-2621. This is the commercial side but they should be able to get you in touch with the domestic side.
6helpful
3answers
Sharp Carousel II Convection Microvave R-3850
My sharp microwave convection oven (R-1870) runs for 59 seconds and stops. If I push start it runs for another 59 seconds and stops. How can this be fixedd?
6helpful
The microwave works for only 8-9 seconds, then stops
It may be in demo mode.  On some units if you hit the timer/clock button 4 times to turn demo off.
Clicking sound sporadically
That particular skillet is just too heavy a load for the turntable system to handle.
I would suggest a lighter skillet or a different container, otherwise, the motor or shaft or both will be damaged.
It is of course perfectly okay to put metal in a microwave (after all, that's what they're made of!) but you just have to do it only according to the instructions in the owner's manual.
And as you know, metal in convection mode poses no problem at all.
You just need to use a lighter or different container.
Our sharp 957 will now only microwave for 59 seconds then stops and rattles for thirty seconds. The convection option stopped working ages ago. Any ideas please?
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
This is also likely why your convection mode stopped working.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
Info on ordering Sharp UK parts / spares is here.
2answers
Setting of a microwave
You can download the owner's manual If you will copy and pastew the entire URL into your browser's address bar:
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=29957&CDCttType=UM&ModelType=C&ModelName=MT1066SB&VPath=UM/200303/20030318134829578_DE68-02235A.pdf
This will be the perfect solution to your problem.
We're happy to help and we appreciate your thoughtful rating of our answer.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
