Although you did not mention what Dock you are using, I assume it is the Camera Dock 6000. Is the Dock connected with the power supply? Because only connected to the PC with a USB cable will not be enough. Also the LiIon battery in the camera, should be charged at least once. If the battery is completely empty the dock will have trouble to. The dock can be used to charge your camera. Then the lights should indicate the state of the battery. And the Dock can be used to transfer pictures to the PC. But before that will work correct you have to install the software that came with the camera. (Easy Share software)
SOURCE: no power
Not sure if this is related, but our's won't start-up either, and it seems to indicate that the batteries are weak/dead prematurely. There must be some sort of power level controller that could be the root problem. Our experts can add some useful content to both these threads....
SOURCE: kodak easyshare camera dock 11
Not a solution, but just today mine is doing the same thing. Left light is on but not charging. I thought maybe it was the batteries needed replacing, but putting the new ones in did not change a thing.
Do these cameras ever go defunct? Guess I will take mine to a camera shop tomorrow and see what they say.
And I just used it to take a picture the other day. Usually by pressing the left light it stars the charge.. but not today.
A
SOURCE: My Kodak EasyShare DX4530 camera dock not charging batteries.
There was an issue with the 4000 series and the NiCd batteries I remember that had to do with the contacts in the camera. The charging circuit is in the camera so you have to make sure that the battery contacts are clean, both on the battery and in the camera.
