Question about Kodak EasyShare Cameras
Kodak dx7590 would not turn on. put in a new charged battery. still would not turn on. connected camera to a dc 5 v adapter, sill will not power up
    New Friend:
LENS ERROR
Posted on Jan 12, 2014
4 Suggested Answers
Anonymous
SOURCE:
Anonymous
SOURCE: My Kodak EasyShare DX4530 camera dock not charging batteries.
There was an issue with the 4000 series and the NiCd batteries I remember that had to do with the contacts in the camera.  The charging circuit is in the camera so you have to make sure that the battery contacts are clean, both on the battery and in the camera.
Posted on Jan 26, 2009
pontelemon
pontelemon
  • 538 Answers
SOURCE: FujiFilm S7000 ac adapter not working
Yes, it is sounds like a fuse(s).
Posted on Apr 23, 2009
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: When trying to charge my M1063 kodak camera the
More times then not it would be the battery, but we do want to leave the diagnosis open to other things because we cannot see the camera from 1000's miles away hope you understand.
1. First check you adaptor make sure you getting voltage at the tip/connector.
2. Check your bettery if its a old battery you might consider replacment.
a. I would also suggest to bring it into a camera shop to have a look over. The camera is worth the fix.
b. You might want to take the battery out and clean the tabs inside and make sure the contacts are clean.
Again more times then not your battery is always to blame in these types of issues, Allot of experts say its the board inside but that is rare so check the above first. When in doubt please do bring it into a shop.
Thanks, Please be considerate and leave postive feedback on how we did today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 18, 2010
Kodak dx7590 camera dock will not light up
Although you did not mention what Dock you are using, I assume it is the Camera Dock 6000. Is the Dock connected with the power supply? Because only connected to the PC with a USB cable will not be enough. Also the LiIon battery in the camera, should be charged at least once. If the battery is completely empty the dock will have trouble to. The dock can be used to charge your camera. Then the lights should indicate the state of the battery. And the Dock can be used to transfer pictures to the PC. But before that will work correct you have to install the software that came with the camera. (Easy Share software)
Jan 12, 2014 | Kodak EasyShare DX7590 Digital Camera
In reference to my Kodak DX7590 camera. I'm sitting here 2 older batteries, and 2 new batteries that I just bought, and no matter which battery I put in the camera, none will turn the camera on. If I...
Hello Terry, Sounds like you have answered your own question, it sounds as if the contacts inside the battery box are either corroded or damaged. If you look down inside the battery box you will see three contacts, look close for corrosion or damage.
Best Regards, Russell
Oct 06, 2011 | Kodak EasyShare DX7590 Digital Camera
My dx7590 will not power up. It shut off without closing the camera lens. New battery did not solve the problem.
Hello Richard, A new battery is not going to solve your problem, you have an internal malfunction in the DX7590 unit that will require a camera tech to repair. The repair will exceed the value of the camera,my advise would be to sell yours on E-Bay for "parts" and by one like it in perfect working order so you can still use all your accessories.
Jun 08, 2010 | Kodak EasyShare DX7590 Digital Camera
I have a DX7590 that won't charge the batteries.
Jeff, you didn't verify the type of battery that you have on your camera, is that the KLIC-5000? if yes then still it will not charged on your dock try to charged your camera using the 5V AC adapter. If your camera will not turn on using the 5V AC adapter or will not turn on using your dock it means the camera is defective and not your battery or charger. You can still contact Kodak repair center at 1 800 665 6515 they will handle your issue.
Feb 09, 2010 | Kodak EasyShare DX7590 Digital Camera
Hi, our kodak dx7590 will start up but a 30seconds
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Dec 29, 2009 | Kodak EasyShare DX7590 Digital Camera
When I turn on my EasyShare M863, it turns off again. I have tried to change the battery, etc. But nothing has helped. I was going to send it in for help, but cannot locate an address. I received this...
1. Remove the batteries from the camera then clean the battery contacts
2. Remove the memory card
3. Insert the battery back on the camera in correct position
4. Place the camera in Auto Mode (auto mode is the green camera icon on the dialing mode)
5. Try to turn it ON (if still doesn't turn ON)
6. Charge the camera plug the USB AC adapter into a working power outlet.
7. Connect the USB cable to your camera and to the USB AC adapter.
8. Camera will charge until light turns off or (up to 3hours) then test the camera if it will turn ON
9. You can also check http://www.kodak.com/go/usbcharging
10.You can also follow the steps on this website www.kodak.com/go/stepbystep
**Contact Kodak support line 1 800 235 6325 (23KODAK)
kodak camera warranty is one year from the date of purchase or from the manufacturing date which ever is longer
Nov 16, 2009 | Kodak EasyShare M1033 Digital Camera
My Kodak Easyshare V1233 will only power up when plugged into the wall charger. Even after staying on the charger it will not power on unless plugged in.
Kodak has 3 types of charger that can be connected to a wall socket
USB AC Adapter - is especially useful when traveling, away from your computer, or just plain on-the-go. Connect your camera's USB cable to the adapter and plug it into a wall outlet to conveniently charge your camera.
5V AC Adapter - Provides in-camera charging for all KODAK EASYSHARE M and V Series Digital Cameras
Input: AC 100-240 V 50/60 Hz Output : DC 5.0 V
3V AC Adapter - Provides direct power to your camera but it will not charge the camera battery
Input: AC 100-240 V 50/60 Hz Output : DC 3.0 V
* You need to check the type of adapter your using. If your using the 5V AC adapter or USB adapter and the camera won't charge the battery contact kodak support line 1 800 235 6325 (23KODAK) for possible repair.
Nov 16, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Battery not charging
Hello June, This sounds pretty easy, I repair these cameras. It sounds like you have a problem with the adapter that plugs into the wall outlet. Remove the battery from the camera and plug the a/c adapter directly in to the camera and try to power on the camera,if it powers on then the problem is the dock,if it do not power on it is the a/c adapter.
Apr 27, 2009 | Kodak EasyShare DX7590 Digital Camera
Battery chargring for Kodak Easyshare DX7590
No. The camera does not have a charger on it. You will have to get a separate charger.
Oct 31, 2008 | Kodak EasyShare C875 Digital Camera
Kodak easyshare m853 digital camera
is the light that's coming on green or red?
if it's red, there's a charging error - contact kodak, they may provide a 5v ac adapter to resolve your charging issue
if it's green, was it blinking or solid? is the battery drained?
if the battery still has a little charge on it, please connect it to the computer then turn it on, check if there's power light
check if the screen is black - that means it's making a connection and the charging is the only issue - computer not detecting it, maybe resolved by kodak's software support
if the camera screen is active - that means there's definitely something wrong with the camera
arrange repairs with kodak, include the battery and usb cable
please visit
www.kodak.com/go/itg - troubleshooting and repair
Feb 13, 2008 | Kodak EasyShare M853 Digital Camera
Cameras Logo
79 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
