1. Pop the hood and locate the horn. These
are typically mounted to the grille or on a bracket in front of the radiator.
2. Loosen the hardware that attaches the
horn to the car with a hex wrench or screwdriver. Horns are usually mounted
with two hex nuts and bolts although some models may use screws to mount the
horn. Remove the hardware then remove the horn assembly by sliding it off the
bracket.
3. Disconnect the horn's electrical
connectors from the wiring harness by depressing the connector tab on the top
of the connector then sliding them free of the connection.
4. Connect the new horn connectors and
install the new horn on the mounting bracket. Install the mounting hardware.
Tighten using the appropriate tool, either a wrench or screwdriver depending on
the hardware and mounting bracket.
Google SinoyElectron to learn more about car diagnostic
Power on the Bluetooth Hardware you want to connect to the computer. You must have some sort of hardware to connect to the computer, in order to enable the Bluetooth connection.
Click "Add" and the computer searches for any Bluetooth hardware in the area. Once it detects the hardware, select it and click "Next."
Type in the passkey for the Bluetooth hardware (found in the device's user manual) and click "Next."
Install any drivers now that came with the Bluetooth hardware. (Insert the driver installation CD that comes with the Bluetooth hardware, wait for the the installation wizard to load onto the screen, accept the license agreement, then click "Next" for the installation name and location and select "Install" to install the drivers.)
Choose "Locate and install driver software" if there are provided drivers. If not, click "Don't show this message again for this device" and click "OK."
hope this helps
