C 1183 problem??? on bizhub 350
10.2.1 C1183: Elevator Motor Ascent/Descent Drive Failure
C11A3 Shutter Drive Failure
• The Shutter Home Position Sensor (PC16-FN) is not unblocked
even after the set period of time has elapsed after the Exit Open/
Close Motor (M6-FN) is energized (beginning of shutter-opening
operation).
• The Shutter Home Position Sensor (PC16-FN) is not blocked even
after the set period of time has elapsed after the Exit Open/Close
Motor (M6-FN) is energized (beginning of shutter-closing operation).
C11B0
Staple Unit CD Drive
Failure
The Staple Home Position Sensor (PC10-FN) is not blocked even
after the set period of time has elapsed after the Stapling Unit Moving
Motor (M7-FN) is energized (beginning of return operation to predetermined
position).
C11B2 Staple Drive Failure
The Home Position Sensor is not blocked even after the set period of
time has elapsed after the Staple Motor is energized (beginning of
staple operation).
C11C0
Punch Cam Motor
Unit Failure
The Punch Motor Pulse Sensor cannot detect both edges of H/L even
after the set period of time has elapsed while the Punch Drive Motor
is energized.
CC155
Finishing Option
Flash ROM Failure
• Data of flash ROM of the finishing options is determined to be faulty
when the power is turned ON.
Code Description Detection Timing
Relevant Electrical Parts
Elevator Motor (M11-FN)
Elevator Tray Home Position Sensor (PC3-FN)
Elevator Tray Lower Limit Sensor (PC14-FN)
Top Face Detection Sensor (PC15-FN)
Elevator Board (PWB-B FN)
Main Control Board (PWB-A FN)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical Component)
Check the M11-FN connector for proper
connection and correct as necessary.
Check M11-FN for proper drive coupling
If OT-601 is connected, check the connector
for proper connection, and correct
as necessary.
Check the installation position of the
OT-601 tray, and correct as necessary.
5
Check the setting of the adjusting plate
for the Exit Tray detection position and
6 M11-FN operation check PWB-A FN PJ7A FN-1 to 2 FS-508 G-7
7 PC3-FN I/O check PWB-A FN PJ12A FN-2 (ON) FS-508 G-4
8 PC14-FN I/O check PWB-B FN PJ2B FN-3 (ON) FS-508 H-6
9 PC15-FN I/O check PWB-B FN PJ2B FN-6 (ON) FS-508 H-6
10 Change PWB-B FN - -
11 Change PWB-A FN - -
ā¢ The Shutter Home Position Sensor (PC16-FN) is not unblocked
operation).
ā¢ The Shutter Home Position Sensor (PC16-FN) is not blocked even
C11B0
Failure
position).
staple operation).
C11C0
Punch Cam Motor
Unit Failure
is energized.
CC155
Finishing Option
Flash ROM Failure
ā¢ Data of flash ROM of the finishing options is determined to be faulty
Step Action
WIRING DIAGRAM
Control Signal
Location
as necessary.
5
You obviously have a finisher fitted to your machine and this code is the detection of the tray lift motor not working. You can reset it in service mode but check that the finisher has not been leant on (as this warps the top and the claws get caught) it may also be the sensor for the tray which is mounted on the rear side of the finisher and is a very fine line between sensing the tray and not and this may need moving slightly.
SOURCE: BIZHUB 350 THROWING CODES C1183 AND NOW SHOWS C5351
Yes, that is it..... The company I purchased the unit from sent a company they use for service out to my house (free of charge)and the finisher needed to be aligned because it was off from the movers who delivered it...It is a fantastic unit...very happy with it.
