Baumatic BFD64SS Diswasher - power light on but can't programme
The power light comes on when pressed and the front panel lights up but nothing happens when I press the programme button. Normally I can select P1 P2 or P3 etc - but nothing works when I press it. Help!
Have the BDW5 full height dishwasher. All the lights are lit at the same time but not flashing, stop button not turning them off. Nothing in the manual under troubleshooting, only mentions probable cause if lights are flashing, which is something to do with door not being closed correctly. Door is definately closing, checked and no obstructions. Had to turn off at mains. Anyone have any ideas. Have the BDW5 full height dishwasher. All the lights are lit at the same time but not flashing, stop button not turning them off. Nothing in the manual under troubleshooting, only mentions probable cause if lights are flashing, which is something to do with door not being closed correctly. Door is definately closing, checked and no obstructions. Had to turn off at mains. Anyone have any ideas.
You can't post conmments that contain an email address.
E3 on BDW45.1 is a failure to reach correct temperature (or the diswasher is unable to dectect the water has reached the correct temperature). You may find the items are not being dried fully.
I have a Frigidaire that does the same thing. I was able to push the start cancel button then select a cycle and press the start button, shut the door and presto it worked.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Check the float switch. If it is stuck the machine will start but no water will be allowed in and the pump will turn on to drain the non existant water. This happens often when a small item gets under the float preventing it from allowing the water valve to open. Find the float in the bottom of your machine and make sure it moves freely.
