Leaking all the time
HI, I can help you. Is the water leaking from the freezer side?
ok, If the water keeps dripping from the fresh water tube in the door, you will need to change the inlet valve. This valve is only activated when electric is sent to it. The valve is sticking open a little and allowing the drip.
I hope this helps you. Please let me know if I can assist yu further.
Vic
It should be on the right hand side in the back take off the compressor cover on the back should be 8 or so 1/4 screws nutdriver type and then two more hold on the water valve. If you have a RO system hooked up to refrig you may need to change the filters on the ro or just change the filter on the refrig. those two will also cause the water to drip thru the valve allowing it to drip on the front
no just from the water on the door.
