Question about Samsung SP-R4232 42 in. Plasma HDTV
No sound on my Samsung tv when I use a HDMI cable
My Samsung 42' TM has no sound with a HDMI connected. I can see the pic. This just started happening. This use to happen with my samsung DVD player when I connected it to the tv. I changed out the HDMI and still the same problem. If I use anyother type of cable besides HDMI cables everything works fine.
  • 57 Answers
Hello..try to change the sound settings to HDMI..you say when you use other cables everything is fine so the TV reconizes the HDMi as a video only so your sound settings should be changed to HDMI
Posted on May 26, 2009
  • anorth73
    anorth73 Nov 08, 2012
    It is set to HDMI when the HDMI cable is hooked up. Will it help to do a factory reset?
6ya staff
SOURCE:
Our hdmi port on our samsung tv is broken... its showing pic and sound but the colour is funny its almost like theres a pink tinge to the colour so its not showing the right colours it should...
Before getting the HDMI port repaired, I would suggest trying a new cable and also make sure that it's the HDMI port on the TV that's bad and not whatever is connected to that port. Try a different DVD player or something... Do you have a different HDMI input on the TV you can use?
Jan 29, 2016 | Samsung Televison & Video
Samsung LN-T4671F HDMI PC hookup and Audio Problems
Pls bear with me, have you tried not using the HDMI/DVI cable but simple straight connection PC > Standard 15 pin VGA cable and audio cable that has "stereo mini-plug" on both ends to the PC IN of the Samsung?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 09, 2008 | Samsung LN-T4671F 46 in. LCD Television
I turn on the Tv the sound comes on & the picture is blank Cablevision was here & said it's a problem in the set
He is probably not an expert (just kidding, of course he's not..) First, try connecting the Cablevision Box to another TV (if you don't have another HD TV, use the yellow/white/red Composite connection.) If there is still no picture, the box is no good. If there is, then try a different output from the Box or other inputs on the TV. Are you using HDMI (HD connection) out of your Box? Is the TV 720p or 1080p? Set the Box up (from the menu) according to the specs of your TV. Hope I helped.
Jan 11, 2011 | Samsung Televison & Video
Ive recently bought a 1080i samsung tv and was wondering will is there any way to connect it to a hdmi cable so i can play my ps3 in better quality?.
IF YOU HAVE A DVI CONECTER A BIG WHITE PLUG WITH MANY CONNECTERS YOU CAN BUY A HDMI -DVI ADAPTER BESIDE THE DVI CONNECTER YOU WILL HAVE INDICATION FOR DVI AUDIO YOU MUST PASS TWO AUDIO CABLES FOR SOUND
Jun 03, 2010 | Samsung HC-P4241W 42" Rear Projection...
I can't get sound from my HDMI Cable.
check the system settings of your console and make sure everything matches what your tv supports. Also check the tv settings so that it reveives audio from the HDMI cable
Aug 09, 2009 | Yamaha HTR-6130 Receiver
All of a sudden, no sound on PS3, great pic though. Using HDMI cable...have checked all connections, reset PS3, etc. Still no sound! Guy from Sony said my HDMI cable(Monster) could be bad?! No sound, but...
I agree with the guy from Sony, the reason for this is the HDMI cable should support the transfer of audio and video over the same cable, if your only getting video over it, the cable could be defective, or its possible that you have another cable in the spot where speakers should go that is over riding the HDMI.
What exactly is the HDMI cable plugged into? Is it direct from TV to PS3?
If you have a stereo set lying around that supports HDMI - try having it run through that.
Is the TV muted? check if you can get sound while watching normal TV channels.
Worst comes to worst, use RCA Plugs remembering that the composite video is (yellow) and stereo audio is (white and red). You don't need to connect the composite video, but connect the stereo audio.
If this did not solve the problem, please leave a comment and I'll get back to you once I can =)
Jul 17, 2009 | Sony Playstation 3 (PS3) Console
Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Sep 24, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Television Won't Display Certain Cable Shows
Okay,i assumed this is what you have:
HD cable box with HDMI cable connection to the Samsung TV.
Listen careful as follow:
First you want to make sure using the same HD comcast box with HDMI connection for our Samsung TV as well as your other TV.Be sure the other TV do received the missing channels from the Samsung TV.You must be SURE you have tested both TVs with the same HDMI cable with the SAME HD cable box.
Now that you have confirmed the both TVS are using the same HD comcast box and the same HDMI cable but the connection that goes to the Samsung TV are missing some channels,at this point,use another HDMI connection behind your Samsung TV and see if you have the same problem.If so,please also try the left side of the HDMI connection and see if you could get the other channels.
Let me know!
solutiondoct
Jun 15, 2008 | Samsung HP-T4254 42 in. Plasma Television
HDMI Cable problem
Well, first you might want to try another hdmi connection behind your TV.If it appears to have the same message,you need to check your TV setup and be sure the HDMI video is active.
Secondly,go with the recommendation of the set top box.You will use component video cable to connect from your set top box component video output(Y PR PB) to your TV (Y PR PB) and see if that actually work.If so,just use the cable box for the time being and call your cable company for another cable box to replace this one!
solutiondoct
Jun 13, 2008 | Samsung HP-T4254 42 in. Plasma Television
Can not connect my MEDION 8828 MD computor via a HDMI cable to my SAMSUNG ps42q97 hdx 42
use a vga connector. this tv doesn't support pc mode on hdmi. don't forget the 3.5mm stereo jack out fron your sound card to the 3.5mm input(next to vga on tv). you will get 1024x768 res.
Dec 23, 2007 | Computers & Internet
Samsung SP-R4232 42 in. Plasma HDTV Logo
2,404 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
