I can't find a way to get to the light bulb
Most microwaves have a shield over the light bulb in the cooking compartment. Some are accessed from the outside most from the inside. Check to see if there are clips or screws that need to be removed to pull the shield off. Careful if there are screws, they are usually coated to prevent the waves from arcing if you crack or break off the coating you could have problems with the microwave arcing
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
