Cannot get google search engine
If you mean you want to make chrome your default browser, follow the steps listed here: Make Chrome your default browser
If you want to make google.com your homepage:
SOURCE: how to change my default browser because now my
Hi. Since you failed to indicate the operating system of your computer, I've shown steps for Windows XP,Windows Vista or Windows 7. Hope this helps.
For Windows XP:
1. Open the Start Menu, and click Set Program Access and Defaults.
2. It will open the Add or Remove Programs window, with the Set Program Access and Default button selected on the left.
Below the "Choose a Configuration" header, click Custom and it will list all the default programs options it found for Default Web Browser, Default E-mail Program, and Default Media Player.
3. Under "Choose a default Web browser", tick Internet Explorer and make sure that all boxes are ticked for "Enable Access to this program."
For Windows Vista or 7, the steps above are almost the same but another way is to :
SOURCE: google chrome not called from
Go to control panel, select "Default Programs" option and in the browser's customization menu set Google Chrome as your default browser to get solved with your problem.
Testimonial: "This was very helpful to find where the default was. When I went to Chrome config and set it as default it didn't change the XP default the first time"
SOURCE: i want to change my
If I understand your question, then you want to change your default search engine from ask.com to google.
Here is what you do. In your search bar, there is a drop down arrow. Click on it, and it shows all the available search engines installed in your browser. To make google your default, simply select it, and that should effect the change.
Hope that was helpful?
Thank you for using FixYa.
SOURCE: how do I set google as my default search engine
In Google Chrome, click on the picture of a Wrench in the top right hand corner. The click on "Options". Near the bottom of the page will be your search options. Click on "Manage Search Engines" to select your default.
In Firefox, click on the Icon in the search box. Then click on "Manage Search Engines". From here you can move google to the top of the list, making it your default search engine. If for some reason you don't see google in the list, you can click on "Get more search engines" to locate and install it.
This small trick will show you how to remove the Google Custom Search page and get the old Google webpage for queries.
If this trick doesn't work try these other suggestions:
