I'm using a Microsoft Lifecam for my webcam, and it does have a microphone built it, however I have a seperate microphone that I'm trying to use for the primary voice recordings.. I cannot figure out how to get the webcam's microphone turned off.
I have tried going to the control panel and disabling it, but that seems to disable the whole webcam. I just want to use my Labtec microphone with the Microsoft webcam, I have tried going into the webcam settings but nothing seems to work.
Im not sure I understood exactly the issue but the solutions are more than one ...
you may just uninstall the web cam ...and set the mic you want to use and after that reinstall the web cam ...and you have every chances to be installed and the external mic to remain in use..
or ...to use the mic from the external pink entry of the pc ...just select it from the sound driver ...options..
in your capture program you might also have the choice for which mic to use ....
in your yahoo messenger for example you have this choice on preferences /audio device....
you also may find on your control panel ...sound and audio device /audio../and for the sound recording audio device ...select the one you want...
good luck !
