SOURCE: burner not working
Sometimes there is "leak" on the cable - the insulation breaks down some place else some the clicking sound is heard but no lighting. Look to see if the arching is at the electrode beside the burner - if it is then try cleaning the electrode and the areas around the burner so as to give better conduction to thr frame o the stove
Regards
SOURCE: Jenn Air gas range- burner not fully lit
Can you verify which burner it is that won`t ignite/burn properly ?
I should be able to help, but I just need some clarity. I`ll watch for your reply.
macmarkus :)
SOURCE: Several Gas Burner Igniters spark every 5 seconds
hi could be a short on the ignition switch of the spark box is stuck in the repeat mode disconnet power and see if this helps
SOURCE: My gas bake burner won't ignite.The igniter is
If the bake
ignitor comes on - check the
amperage on
the bake ignitor wires when it's on. Amperage should be 3 - 3.6A. If
less
than 3A - replace ignitor.
Ignitor part numbers (any will do, but the first one is a direct replacement): 12400035, WB13K21, WB2X9998, SGR412, NR020,
5303935066, 814269, 9753108.
All those are interchangeable, if
you can splice the wires.
