When i try new batteries it wont turn on.i think there is something wrong with the battery springs.someone please help.when i was 4 years old my uncle gave it to me as a gift!
Some times the springs and plates in the battery compartment need cleaning. Did this to my classic Gameboy and the thing works like it's new.
Extreme cases the Gameboy Color has 2 fuses that can burn from age or voltage input is too high these are easy to replace or just patch if you have skill with a soldering iron.
SOURCE: Wont charge or turn on
usually when cords are wrapped around the base of the plug, it creats a short in the cord. And most people *do* wrap cords around objects to create convienent space. basicly it was the cord not the system.
SOURCE: my game boy color doesn't turn on
theres a broken connection somewhere if even the LED doesn't even come on. I doubt theres even an internal fuse on the gameboy.
The only thing you might be able to fix was a faulty on/off switch - have you tried shorting the switch contacts with something metal?
SOURCE: My Nintendo DS won't stay on.
try charging it, or if that doesnt work,the battery might be in incorrectly, or one of the battery pins is broken or bent.if the battery is in incorrectly try putting it in again.if one of the pins is bent try carefully bending it back.if one is bro0ken,you might consider a new DS.there could also be forien material in thew battery compartment, in which case you would extract.if none of these solutions work,it might either be the battery(in which case you would buy a new one)or an intenal problem (which would lead me to consider a new DS)
SOURCE: Leapfrog Leapster touch screen
Got my son's to work. Used these instructions.
Question
Why doesn;t my Leapster2 respond to the stylus pen?
Answer
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted
2) Hold down the Hint button while turning the unit on
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
SOURCE: Game boy color game won't play
You cant fix the cartrige as you will break it
overall its time to let go of the game boy color games try getting a DS its much better but back to your problem... IT IS NOT THE CARTRIGE!! your game boy will not accept the cartrige because of the mechanics in it deteriorating
