Replacing motor only how do I unassemble motor from empeller
In order to remove the motor, first turn the motor locking ring. This holds the too halves of the pump together. There should be a small tab you have to press in, then grab the round handle, and spin the outer sleeve to unlock. Once you do this the back half of the can be pulled away. This can be very hard sometimes. If the pump and motor still work, you can flip the switch on for a sec or two, and it will pop the back half away from the front half. If the motor is not working then you'll just have to twist, wiggle and pull till you get it apart. After this make sure the power is off, breaker off, etc. and you can remove two screw from the plastic cover on the tail of the motor and disconnect the wires, and remove that half the pump. Next step is to just pull off the diffuser, which may actually have stuck inside the front half the pump. Next remove the impeller, by unscrewing while locking the shaft from the rear with a wrench. if there is a screw in the center of the impeller threaded into motor shaft remove that first. This should be a left handed thread, so unscrew by turning clockwise. The impeller should unscrew counter clockwise like normal. Next remove the seal plate. That should expose 4 bolts holding the motor to the motor mounting plate. Once you remove this you can remove the old seal, clean, and install new seal. you should replace the diffuser and seal plate o-ring as well. Normally I don't recommend a lot of lube on o-rings, but this one can be a bugger to get back together, so use plenty of lube. As I said getting the back half inserted back into the front half is a pain, so you'll just have to work it. Make sure the motor locking ring is forward of the mounting brace that sits on the ground. This can be hard, but if you get it at the right angle it will go raight in place. Make sure the diffeser and/or diffuser o-ring does not slip off into the pump housing when your trying to get it lined up and back into place. There is a notch in the housing and seal plate that have to line up. Sometimes a clamp or ratcheting strap can be used to help pop the two halves back together.
Now all that being said.... it might be worth it to just take the whole pump in to a pump repair shop and let them rebuild it, or put a new motor and seals for ya. At least check the price and consider it. This pump has unions to install it so there is no pipe work required to remove the whole darn thing. Good Luck, and let me know if you have more questions.
I figured it out myself.
Shut down the power source. Wherever your breaker is located.
a) remove the 2 screws that cover the back of the motor
b) remove the 3 screws that are approximately at 11, 1, and 7 o'clock. The are about 6 inches long
c) loosen the large circular ring that binds the motor to the pump
d) the motor will separate for the pump.
To reinstall,
reverse the process
All I can say is it worked for me,
Disclaimer... I am not a professional
Which model filter is it? The JC55/40 have a connector that has a locking ring on the pump side but is threaded into the tank. Clarification would be helpful.
