SOURCE: Standby flashing red light
Hi
you have defctive power supply section, in the power oscillation circuit!
do you know how to repair a tv? if you know i teach you how to solved it.
SOURCE: Sony Trinitron KV-24FS100 red light flashes 4 times
your tv had a problem.if you have a knowledge in electronics, check or replace the horizontal transistor beside the plyback. it is a black square parts with 3 pins.
SOURCE: no picture
My picture would go out after several minutes but I still had sound. I took the rear cover off and blew all the dust off with compresed air.I did this for a few times over several days nothing happened.I also took off the rear circuit board that attaches to the tube with a round pin socket and blew that with compressed air and put it back on. The TV has now worked for two days without the picture going out. It worked!!!!!!!!!!!!!! My tv was 9 years old.
SOURCE: power clicks on and red power light flashes but no picture
Sounds like it could be the flyback transformer, time to leave CRTs and go to LCD, LED or Plasma.
SOURCE: kv-32fs16, no picture or sound , red lights flash 4 times
Hi
In sony tv`s the 4 blink code(sony error codes)usually means that there is a vertical deflection problem.
It is often caused by a faulty vertical output i.c and/or related components.
If you feel handy with a soldering iron let me know and i`ll help you with it.
Hope this help Merry Christmas
