broken faders...bad muting fet on master buss, dirty insert jack on stereo buss...could be a lot of things, last drive stage to output, got hot neutral feedback on snake and blew the final stages...
Theres a little switch next to where it says media in on your front panel just above the group sliders.This little button needs to be pressed down otherwise your cd won't come thru.
It looks like using the GROUP output to drive the external FX and then bringing that back into the EFX return is about the only thing you can do in short of putting the effects after the main outputs then it would be on everything.
You will need toput power amplifiers that drive the speakers and then connect the board to the power amps. Use BALANCED interconnects for this and power the board from the same receptacle or surce as the amps.
